outdated documentation on how to install brickd on Debian
Geschrieben (bearbeitet)
It seems that the documentation on how to install brickd on an actual debian bullseye is outdated and is using some depricated methods (like apt-key add) and also "lsb" commands...
Can this documentation be updated - or is there already an updated version available somewhere?
1. The usage of "apt-key add" - apt-key is depricated
root@tinkerforge-server:~# wget https://download.tinkerforge.com/apt/$(lsb_release -is | tr [A-Z] [a-z])/archive.key -q -O - | apt-key add -
-bash: lsb_release: command not found
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
gpg: no valid OpenPGP data found.
2. lsb_release "command not found"
The usage of lsb_command requires lbs-core but this seems to be depricated, too:
Zitat
And LSB for Debian was a Standard Core System that Third-Party Applications written for GNU/Linux could Depend Upon.
Especially relevant: as for the actual Debian Specifications this Library is Deprecated.
bearbeitet von CChris
