lkün Geschrieben October 10, 2022 at 16:03 Geschrieben October 10, 2022 at 16:03 Hallo, ich verscuhe gerade meine Warp 2 Box in EVCC unter Home Assistant einzubinden. Das Ad-On ist installiert und es muss eigentlich "nur" die evcc.yaml richtig erstellt werden. Dabei bekomme ich jedoch immer wieder die Fehlermeldung, dass der charger nicht erstellt werden kann. Meine Fehlermeldung lautet im Protokoll: Using config file: /config/evcc.yaml starting evcc: 'evcc --config /config/evcc.yaml' [main ] INFO 2022/10/10 17:36:56 evcc 0.104.2 [main ] INFO 2022/10/10 17:36:56 using config file: /config/evcc.yaml [main ] INFO 2022/10/10 17:36:56 listening at :7070 [warp ] INFO 2022/10/10 17:36:56 connecting evcc-1901320301 at tcp://192.168.x.xxx:1883 [main ] FATAL 2022/10/10 17:36:56 cannot create charger 'WARP2': cannot create charger 'template': cannot create charger 'warp': error connecting: not Authorized [main ] FATAL 2022/10/10 17:36:56 will attempt restart in: 5m0s Die yaml lautet: Network: schema: http host: 192.168.X.XXX # IP vom Home Assistant # port is the listening port for UI and api # evcc will listen on all available interfaces port: 7070 interval: 10s # control cycle interval # log settings log: info levels: site: debug lp-1: debug lp-2: debug # meter definitions # name can be freely chosen and is used as reference when assigning meters to site and loadpoints # for documentation see https://docs.evcc.io/docs/devices/meters meters: - name: gridmeter type: custom power: source: script cmd: /bin/sh -c 'echo -1000' - name: pvmeter type: custom power: source: script cmd: /bin/sh -c 'echo 9000' # charger definitions # name can be freely chosen and is used as reference when assigning charger to vehicle # for documentation see https://docs.evcc.io/docs/devices/chargers chargers: - name: WARP2 type: template template: tinkerforge-warp fw2: # Firmware v2 installiert host: 192.168.x.xxx # IP Adresse oder der Hostname des MQTT Brokers #port: 1883 # MQTT Broker Port # Optional topic: warp2/Xb6 # Topic (ohne / am Anfang) # Optional # vehicle definitions # name can be freely chosen and is used as reference when assigning vehicle to loadpoint # for documentation see https://docs.evcc.io/docs/devices/vehicles vehicles: - name: my_car type: custom title: Mein Auto # display name for UI capacity: 50 # byttery capacity (kWh) # site describes the EVU connection, PV and home battery site: title: Home # display name for UI meters: grid: gridmeter # grid meter #pvs: # - pv # list of pv inverters/ meters #battery: battery # battery meter #prioritySoC: # give home battery priority up to this soc (empty to disable) #bufferSoC: # ignore home battery discharge above soc (empty to disable) # loadpoint describes the charger, charge meter and connected vehicle loadpoints: - title: Garage # display name for UI charger: WARP2 # charger meter: gridmeter # charge meter mode: "off" # set default charge mode, use "off" to disable by default if charger is publicly available # vehicle: car1 # set default vehicle (disables vehicle detection) resetOnDisconnect: true # set defaults when vehicle disconnects soc: # polling defines usage of the vehicle APIs # Modifying the default settings it NOT recommended. It MAY deplete your vehicle's battery # or lead to vehicle manufacturer banning you from API use. USE AT YOUR OWN RISK. poll: # poll mode defines under which condition the vehicle API is called: # charging: update vehicle ONLY when charging (this is the recommended default) # connected: update vehicle when connected (not only charging), interval defines how often # always: always update vehicle regardless of connection state, interval defines how often (only supported for single vehicle) mode: charging # poll interval defines how often the vehicle API may be polled if NOT charging interval: 60m estimate: true # set false to disable interpolating between api updates (not recommended) phases: 3 # electrical connection (normal charger: default 3 for 3 phase, 1p3p charger: 0 for "auto" or 1/3 for fixed phases) enable: # pv mode enable behavior delay: 1m # threshold must be exceeded for this long threshold: 0 # grid power threshold (in Watts, negative=export). If zero, export must exceed minimum charge power to enable disable: # pv mode disable behavior delay: 3m # threshold must be exceeded for this long threshold: 0 # maximum import power (W) guardDuration: 5m # switch charger contactor not more often than this (default 5m) minCurrent: 6 # minimum charge current (default 6A) maxCurrent: 16 # maximum charge current (default 16A) # tariffs are the fixed or variable tariffs # cheap (tibber/awattar) can be used to define a tariff rate considered cheap enough for charging tariffs: currency: EUR # three letter ISO-4217 currency code (default EUR) grid: # either static grid price type: fixed price: 0.321 # EUR/kWh Ich verstehe nicht ganz wo der Fehler liegen soll. Unter Network habe ich die IP Adresse vom Home Assistant angegeben. Unter charger haben ich die IP Adresse vom MQTT Broker (ebenfalls Home Assistent) eingetragen. Warum kann sich EVCC nicht mit der Warp2 verbinden? Mit MQTT Explorer kann ich auf die Warp2 zugreifen und konnte sie auch im Homeassistent einbinden. Hat jemand eine Idee? Zitieren
rtrbt Geschrieben October 11, 2022 at 08:28 Geschrieben October 11, 2022 at 08:28 Not Authorized als Fehler ist interessant. Hast du bei deinem MQTT-Broker Benutzername und Passwort konfiguriert? Dann musst du das in der EVCC-Konfiguration eintragen. Frag ansonsten am besten auch mal im EVCC-Forum: https://github.com/evcc-io/evcc/discussions Zitieren
PV-Michel Geschrieben December 30, 2022 at 23:48 Geschrieben December 30, 2022 at 23:48 Am 10.10.2022 um 18:03 schrieb lkün: Hallo, ich verscuhe gerade meine Warp 2 Box in EVCC unter Home Assistant einzubinden. Das Ad-On ist installiert und es muss eigentlich "nur" die evcc.yaml richtig erstellt werden. Dabei bekomme ich jedoch immer wieder die Fehlermeldung, dass der charger nicht erstellt werden kann. Meine Fehlermeldung lautet im Protokoll: Using config file: /config/evcc.yaml starting evcc: 'evcc --config /config/evcc.yaml' [main ] INFO 2022/10/10 17:36:56 evcc 0.104.2 [main ] INFO 2022/10/10 17:36:56 using config file: /config/evcc.yaml [main ] INFO 2022/10/10 17:36:56 listening at :7070 [warp ] INFO 2022/10/10 17:36:56 connecting evcc-1901320301 at tcp://192.168.x.xxx:1883 [main ] FATAL 2022/10/10 17:36:56 cannot create charger 'WARP2': cannot create charger 'template': cannot create charger 'warp': error connecting: not Authorized [main ] FATAL 2022/10/10 17:36:56 will attempt restart in: 5m0s Die yaml lautet: Network: schema: http host: 192.168.X.XXX # IP vom Home Assistant # port is the listening port for UI and api # evcc will listen on all available interfaces port: 7070 interval: 10s # control cycle interval # log settings log: info levels: site: debug lp-1: debug lp-2: debug # meter definitions # name can be freely chosen and is used as reference when assigning meters to site and loadpoints # for documentation see https://docs.evcc.io/docs/devices/meters meters: - name: gridmeter type: custom power: source: script cmd: /bin/sh -c 'echo -1000' - name: pvmeter type: custom power: source: script cmd: /bin/sh -c 'echo 9000' # charger definitions # name can be freely chosen and is used as reference when assigning charger to vehicle # for documentation see https://docs.evcc.io/docs/devices/chargers chargers: - name: WARP2 type: template template: tinkerforge-warp fw2: # Firmware v2 installiert host: 192.168.x.xxx # IP Adresse oder der Hostname des MQTT Brokers #port: 1883 # MQTT Broker Port # Optional topic: warp2/Xb6 # Topic (ohne / am Anfang) # Optional # vehicle definitions # name can be freely chosen and is used as reference when assigning vehicle to loadpoint # for documentation see https://docs.evcc.io/docs/devices/vehicles vehicles: - name: my_car type: custom title: Mein Auto # display name for UI capacity: 50 # byttery capacity (kWh) # site describes the EVU connection, PV and home battery site: title: Home # display name for UI meters: grid: gridmeter # grid meter #pvs: # - pv # list of pv inverters/ meters #battery: battery # battery meter #prioritySoC: # give home battery priority up to this soc (empty to disable) #bufferSoC: # ignore home battery discharge above soc (empty to disable) # loadpoint describes the charger, charge meter and connected vehicle loadpoints: - title: Garage # display name for UI charger: WARP2 # charger meter: gridmeter # charge meter mode: "off" # set default charge mode, use "off" to disable by default if charger is publicly available # vehicle: car1 # set default vehicle (disables vehicle detection) resetOnDisconnect: true # set defaults when vehicle disconnects soc: # polling defines usage of the vehicle APIs # Modifying the default settings it NOT recommended. It MAY deplete your vehicle's battery # or lead to vehicle manufacturer banning you from API use. USE AT YOUR OWN RISK. poll: # poll mode defines under which condition the vehicle API is called: # charging: update vehicle ONLY when charging (this is the recommended default) # connected: update vehicle when connected (not only charging), interval defines how often # always: always update vehicle regardless of connection state, interval defines how often (only supported for single vehicle) mode: charging # poll interval defines how often the vehicle API may be polled if NOT charging interval: 60m estimate: true # set false to disable interpolating between api updates (not recommended) phases: 3 # electrical connection (normal charger: default 3 for 3 phase, 1p3p charger: 0 for "auto" or 1/3 for fixed phases) enable: # pv mode enable behavior delay: 1m # threshold must be exceeded for this long threshold: 0 # grid power threshold (in Watts, negative=export). If zero, export must exceed minimum charge power to enable disable: # pv mode disable behavior delay: 3m # threshold must be exceeded for this long threshold: 0 # maximum import power (W) guardDuration: 5m # switch charger contactor not more often than this (default 5m) minCurrent: 6 # minimum charge current (default 6A) maxCurrent: 16 # maximum charge current (default 16A) # tariffs are the fixed or variable tariffs # cheap (tibber/awattar) can be used to define a tariff rate considered cheap enough for charging tariffs: currency: EUR # three letter ISO-4217 currency code (default EUR) grid: # either static grid price type: fixed price: 0.321 # EUR/kWh Ich verstehe nicht ganz wo der Fehler liegen soll. Unter Network habe ich die IP Adresse vom Home Assistant angegeben. Unter charger haben ich die IP Adresse vom MQTT Broker (ebenfalls Home Assistent) eingetragen. Warum kann sich EVCC nicht mit der Warp2 verbinden? Mit MQTT Explorer kann ich auf die Warp2 zugreifen und konnte sie auch im Homeassistent einbinden. Hat jemand eine Idee? Bist Du da weitergekommen..? Ich hab grad ein ähnliches Problem... LG Michael Zitieren
Hansiputz Geschrieben January 15, 2023 at 18:34 Geschrieben January 15, 2023 at 18:34 Hi Habe eben mit genau dem gleichen Problem gekämpft. Scheint zu laufen wie folgt: mqtt: broker: 192.168.93.203:1883 user: mqtt password: xxxx chargers: - type: template template: tinkerforge-warp fw2: true host: 192.168.93.203 port: 1883 topic: warp2/22rE timeout: 30s name: warp2 user: mqtt password: xxxx Alos Benutzer / Pwd unter der MQTT Broker Definition UND im Charger erintragen Zitieren
Hansiputz Geschrieben January 15, 2023 at 18:35 Geschrieben January 15, 2023 at 18:35 Sorry für die vielen Leerzeilen. Die waren beim Editieren noch nicht da :-( Zitieren
inuites Geschrieben February 2, 2023 at 16:10 Geschrieben February 2, 2023 at 16:10 Dear all, I have installed my warp2-pro with mqtt. Everything is working. I'm trying to setup EVCC (HA-addon) but I have an error "missing loadpoints" whereas my configuration (mqtt ip and topic are the good one) as I see evcc and my wallbox into mqtt explorer. Any idee ? Thank you ! network: schema: http host: evcc.local # .local suffix announces the hostname on MDNS port: 7070 mqtt: broker: 192.168.1.10:1883 topic: evcc log: info levels: cache: error interval: 10s # control cycle interval chargers: - name: warp2 type: template template: tinkerforge-warp fw2: true host: 192.168.1.10 port: 1883 topic: warp2/pro loadpoints: - title: Garage charger: warp2 mode: off phases: 3 mincurrent: 6 maxcurrent: 16 resetOnDisconnect: false meters: - nom : pv_meter type : custom power : source : mqtt cmd : homeassistant/meter/prod_instant - nom : grid_meter type : custom power : source : mqtt cmd : homeassistant/meter/puissance_globale site: title: Home meters: grid: grid_meter pv: pv_meter Zitieren
inuites Geschrieben February 2, 2023 at 16:11 Geschrieben February 2, 2023 at 16:11 (bearbeitet) vor 2 Stunden schrieb inuites: Dear all, I have installed my warp2-pro with mqtt. Everything is working. I'm trying to setup EVCC (HA-addon) but I have an error "missing loadpoints" whereas my configuration (mqtt ip and topic are the good one) as I see evcc and my wallbox into mqtt explorer. Any idee ? Thank you ! network: schema: http host: evcc.local # .local suffix announces the hostname on MDNS port: 7070 mqtt: broker: 192.168.1.10:1883 topic: evcc log: info levels: cache: error interval: 10s # control cycle interval chargers: - name: warp2 type: template template: tinkerforge-warp fw2: true host: 192.168.1.10 port: 1883 topic: warp2/pro loadpoints: - title: Garage charger: warp2 mode: off phases: 3 mincurrent: 6 maxcurrent: 16 resetOnDisconnect: false meters: - nom : pv_meter type : custom power : source : mqtt cmd : homeassistant/meter/prod_instant - nom : grid_meter type : custom power : source : mqtt cmd : homeassistant/meter/puissance_globale site: title: Home meters: grid: grid_meter pv: pv_meter Resolved. It was a problem in vscode that was not saving correctly the file.. sorry bearbeitet February 2, 2023 at 18:37 von inuites Zitieren
