bjorn Geschrieben October 10, 2022 at 11:07 Share Geschrieben October 10, 2022 at 11:07 Is there a way to read the UID of a device without knowing the UID of the device? I can only get an answer when calling the function _get_identity AFTER i already connected to the brick using _create. And in "create" i need the UID Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
rtrbt Geschrieben October 11, 2022 at 08:20 Share Geschrieben October 11, 2022 at 08:20 For that you can use the IP connection's enumerate callback. See here for an example: https://www.tinkerforge.com/en/doc/Software/IPConnection_C.html#enumerate This will report all connected Bricks and Bricklets with their UID and more. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
bjorn Geschrieben October 25, 2022 at 06:34 Autor Share Geschrieben October 25, 2022 at 06:34 Am 11.10.2022 um 10:20 schrieb rtrbt: For that you can use the IP connection's enumerate callback. See here for an example: https://www.tinkerforge.com/en/doc/Software/IPConnection_C.html#enumerate This will report all connected Bricks and Bricklets with their UID and more. Thank you! I will try this later. I gotta say that tinkerforge documents isnt very helpful about this. For the most part, they just say that "the easiest way is to use brickviewer" :) Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
