Mazen Mohsen Geschrieben August 25, 2022 at 12:48 Geschrieben August 25, 2022 at 12:48 Hello, I want to control 10 mg996R which can use up to 1A. what is the Maximum current that servo bricket 2.0 can handle. Can I give it 5v 15A from input terminals from a power supply or will it burn? Zitieren
borg Geschrieben August 26, 2022 at 08:10 Geschrieben August 26, 2022 at 08:10 If the connectors get too hot you can always connect your power supply directly to the servo. So connect 5V/GND to the servo directly and only GND/PWM signal to the Servo Bricklet. The current doesn't have to flow through the Bricklet! Zitieren
