Get outdoor weather station identifier
Loïc G.
Hello !
I'm trying to get the data from a Outdoor Weather bricklet using the C/C++ bindings from uC.
I want to use `tf_outdoor_weather_get_station_data` instead of the callback methods. For this I first need to get the station identifier using `tf_outdoor_weather_get_station_identifiers` but I'm unable to get it to work.
uint8_t * stations_id;
uint16_t * station_nb;
tf_outdoor_weather_get_station_identifiers(&ow, stations_id, station_nb);
tf_hal_printf("nb: %I16u - station 1: %I16u\n", station_nb, stations_id);
Returns 0 for both the values.
I get correct values when using the callback methods so the communication is working.
Any clue on what I'm doing wrong ?
On 8/13/2022 at 8:18 PM, Loïc G. said:
I think it can be done in a better way using a pointer instead of a array of 255 uint8_t elements
Nope, you have to pass a buffer with enough space for 256(!) entries. The station IDs are collected in this buffer and the Bricklet can detect up to 256 stations.
Theoretically you cound call
tf_outdoor_weather_get_station_identifiers(&this->ow, nullptr, &station_nb);
first to get the number of stations and then creating a buffer that is large enough, for example with
uint8_t *stations_id = (uint8_t*) malloc(stations_nb * sizeof(uint8_t));
However this is dangerous, as the Bricklet could receive another new station after the call to get the number of stations, but before the second call to get the station IDs. So don't do this!
