The go API Binding Version 2.0.12 for CAN V2 Bricklet does not work correctly.
I set the module in Transceiver Loopback Mode.
I send a frame with 8 bytes.
Only the first byte is correct, all others are zero.
Sending a frame with less than 8 bytes results in all bytes being zero
can.SetTransceiverConfiguration(uint32(*bitrate), 800, can_v2_bricklet.TransceiverModeLoopback)
can.WriteFrame(can_v2_bricklet.FrameTypeStandardData, 1742, []uint8{42, 23, 17, 42, 23, 17, 42, 23})
On bus --> 2A 00 00 00 00 00 00 00
Has anyone seen a similar problem?
Sure,
As per https://www.tinkerforge.com/en/doc/Software/API_Bindings_Go.html#from-source and https://go.dev/doc/gopath_code
there should be a directory named "go" in your home directory (so /home/[your_username], C:\Users\[your_username], or similar). In the zip there is a github.com directory. Put this directory into .../go/src/ so that afterwards you have .../go/src/github.com/Tinkerforge/...
If is already a github.com directory in ../go/src (as you've already got an older version of the bindings installed), you can either remove .../go/src/github.com/Tinkerforge/ or overwrite all files when extracting the zip.
Thanks, I did as you told me. but I am using go.mod.
When I try to build, I get
main.go:10:2: no required module provides package github.com/Tinkerforge/go-api-bindings/can_v2_bricklet; to add it:
        go get github.com/Tinkerforge/go-api-bindings/can_v2_bricklet
What do I have to write in go.mod to tell go to use the package in GOPATH?
Okay, the Go bindings are not yet adapted to go.mod, but you can do that yourself for now.
Unpack the ZIP file to somwhere, doesn't matter where. Run "go mod init github.com/Tinkerforge/go-api-bindings" in the github.com/Tinkerforge/go-api-bindings directory from the unpacked ZIP file.
To your go.mod file add a line like this, to tell Go where to find the module locally:
replace github.com/Tinkerforge/go-api-bindings => /path/to/your/github.com/Tinkerforge/go-api-bindings
Go bindings 2.0.13 published. Those will just work now, without modification. You can also remove the replace line from your go.mod file again.
100 FPS is too low, you should be able to send 500 FPS and receive 1000 FPS.
This example sends about 500 FPS with two CAN Bricklet 2.0 connected to form a CAN bus:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
HOST = "localhost"
PORT = 4223
UID1 = "Er1" # Change XYZ to the UID of your CAN Bricklet 2.0
UID2 = "Gj8" # Change XYZ to the UID of your CAN Bricklet 2.0
from tinkerforge.bricklet_can_v2 import BrickletCANV2
# Callback function for frame read callback
def cb_frame_read(frame_type, identifier, data):
    if frame_type == BrickletCANV2.FRAME_TYPE_STANDARD_DATA:
        print("Frame Type: Standard Data")
    elif frame_type == BrickletCANV2.FRAME_TYPE_STANDARD_REMOTE:
        print("Frame Type: Standard Remote")
    elif frame_type == BrickletCANV2.FRAME_TYPE_EXTENDED_DATA:
        print("Frame Type: Extended Data")
    elif frame_type == BrickletCANV2.FRAME_TYPE_EXTENDED_REMOTE:
        print("Frame Type: Extended Remote")
    print("Identifier: " + str(identifier))
    print("Data (Length: " + str(len(data)) + "): " + ", ".join(map(str, data[:min(len(data), 8)])))
    print("")
if __name__ == "__main__":
    can1 = BrickletCANV2(UID1, ipcon) # Create device object
    can2 = BrickletCANV2(UID2, ipcon) # Create device object
    # Configure transceiver for loopback mode
    can1.set_transceiver_configuration(1000000, 625, can1.TRANSCEIVER_MODE_NORMAL)
    can2.set_transceiver_configuration(1000000, 625, can2.TRANSCEIVER_MODE_NORMAL)
    # Register frame read callback to function cb_frame_read
    #can2.register_callback(can2.CALLBACK_FRAME_READ, cb_frame_read)
    # Enable frame read callback
    can2.set_frame_read_callback_configuration(True)
    # Write standard data frame with identifier 1742 and 3 bytes of data
    import time
    c = 0
    s = time.monotonic()
    f = 0
    while True:
        time.sleep(0.0001)
        if not can1.write_frame(can1.FRAME_TYPE_STANDARD_DATA, 1742, [42, 23, 17]):
            f += 1
            if f % 100 == 0:
                print('fails', f)
            continue
        c += 1
        if c % 100 == 0:
            n = time.monotonic()
            d = n - s
            #print('c', c, d, d / c, c / d)
            print('fps', c / d)
    input("Press key to exit\n") # Use raw_input() in Python 2
    can2.set_frame_read_callback_configuration(False)
    ipcon.disconnect()
