Superp Geschrieben June 30, 2022 at 08:59 Geschrieben June 30, 2022 at 08:59 Dear Tinkerforge, I am aware a GPS Bricklet 3.0 is in the pipeline. I am assuming V3 will support Galileo, and V2 will not be upgraded to support Galileo. Can you share with us: When V3 will become available, and How it will be different from V2? I have a little project incorporating a GPS, and at some point want to finalise the design and order the parts (using a GPS V2 for prototyping at the moment). Thanks for any info. Zitieren
batti Geschrieben June 30, 2022 at 12:38 Geschrieben June 30, 2022 at 12:38 Hi, GPS V3 will use PA1616D instead of Firefly X1. The ICs are quite similar. You are right, V3 will have Galileo support. We will release GPS V3 in the next days. We already have it in stock but need to finish the documentation and shop item. 1 Zitieren
borg Geschrieben July 4, 2022 at 15:46 Geschrieben July 4, 2022 at 15:46 Now available: https://www.tinkerforge.com/en/shop/gps-v3-bricklet.html 🙂 Zitieren
Superp Geschrieben July 4, 2022 at 19:36 Autor Geschrieben July 4, 2022 at 19:36 I already ordered one earlier today. All looks fine, size is now 40x40mm. The documentation seems a bit inconsistent re onboard antenna? Zitieren
borg Geschrieben July 5, 2022 at 08:43 Geschrieben July 5, 2022 at 08:43 vor 13 Stunden schrieb Superp: The documentation seems a bit inconsistent re onboard antenna? It is fixed now. There was a bit too much copy+paste from GPS V2 documentation. Zitieren
