Zerin Geschrieben May 20, 2022 at 01:53 Share Geschrieben May 20, 2022 at 01:53 Hallo, Ich versuche, die Sensordaten alle 10 Sekunden abzurufen und in einer CSV-Datei zu speichern. Ich brauche kontinuierliche Daten. Aber ich erhalte einen Fehler. Den Code habe ich angehängt HOST = "192.168.0.104" PORT = 4223 UID_tem = "Nwv" # Change XYZ to the UID of your Temperature Bricklet 2.0 import csv from tinkerforge.ip_connection import IPConnection def cb_temperature(temperature): print("Temperature: " + str(temperature/100.0) + " °C") output1.writerow([str(temperature/100.0)]) if __name__ == "__main__": ipcon = IPConnection() # Create IP connection t = BrickletTemperatureV2(UID_tem, ipcon) # Create device object ipcon.connect(HOST, PORT) # Connect to brickd t.set_temperature_callback_configuration(1000, False, "x", 0, 0) csvfile1= open ('/home/pi/temp1_data.csv','wb') output1 = csv.writer(csvfile1,delimiter=';', quotechar='|') output1.writerow(['temperature']) t.register_callback(t.CALLBACK_TEMPERATURE, cb_temperature) csvfile1.close() input("Press key to exit\n") # Use raw_input() in Python 2 ipcon.disconnect() Ich erhalte den folgenden Fehler: Exception in thread Callback-Processor: Traceback (most recent call last): File "/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner self.run() File "/usr/lib/python3.9/threading.py", line 892, in run self._target(*self._args, **self._kwargs) File "/home/pi/.local/lib/python3.9/site-packages/tinkerforge/ip_connection.py", line 1239, in callback_loop self.dispatch_packet(data) File "/home/pi/.local/lib/python3.9/site-packages/tinkerforge/ip_connection.py", line 1219, in dispatch_packet cb(unpack_payload(payload, form)) File "/home/pi/Desktop/testtempcsv.py", line 23, in cb_temperature output1.writerow([str(temperature/100.0)]) ValueError: I/O operation on closed file. Kann mir jemand freundlicherweise sagen, wie ich das beheben kann? Danke :) Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
poohnet Geschrieben May 20, 2022 at 05:49 Share Geschrieben May 20, 2022 at 05:49 Moin, ohne das jetzt ausprobiert zu haben, würde ich sagen, dass die beiden Zeilen "csvfile1.close()" und "input("Press key to exit\n") # Use raw_input() in Python 2" getauscht werden müssen. Wenn der Callback aufgerufen wird, ist die Datei ansonsten nämlich schon wieder geschlossen... Gruß Thomas Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
