Tim1118 Geschrieben May 12, 2022 at 07:01 Share Geschrieben May 12, 2022 at 07:01 Hello, I plan to use some Laser-Sensors outside so I want to try to make them as waterproof as possible. Therefore I bought this Epoxidharz-Spray which should be perfect for this problem. At the moment I'm not pretty shure if this will work out well because of the heat the sensor might produce. Unfortunately I have no thermometer to check this. Did anybody already do that and has some experience or just recommandations for me? Many thanks in advance if anyone can help!!! Greetings Tim Finmans Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
batti Geschrieben June 7, 2022 at 13:06 Share Geschrieben June 7, 2022 at 13:06 Hi Tim, this spray is used often when protecting PCBs/make them waterproof. That's fine for that. Of course you can't apply it onto sensors etc. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
