Tim1118 Geschrieben May 10, 2022 at 08:40 Share Geschrieben May 10, 2022 at 08:40 Hello, at the moment I try to read data from the CAN-Bus of my Opel Corsa with the CAN-Bricklet. The Ground, CAN-H and CAN-L are connected via an OBD2 cable to the CAN-Bricklet. All three LEDs light up constantly. I'm getting lots of format, stuffing and read errors which you can see in the picture I sent. I'm using this OBD2-cable which has lots of reviews that the pinout might be wrong for some cables so this could also cause the errors if I just connect some wrong cabels because of the wrong pinout. About testing out which cable is CAN-H or CAN-L I couldn't find that much... Does it matter if I connect the chassis ground (4) or the signal ground(5)? I've tried both and it doesn't work but anyways I don't think this is causing any errors. I hope somebody can help. Many thanks in advance! Best regards Tim F Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben May 10, 2022 at 09:00 Share Geschrieben May 10, 2022 at 09:00 Did you try different baud rates? See section "3.1 Guessing the baud rate." here: https://www.instructables.com/How-to-Hack-and-Upgrade-Your-Car-Using-CAN-Bus/ Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Tim1118 Geschrieben May 10, 2022 at 10:08 Autor Share Geschrieben May 10, 2022 at 10:08 Many thanks! I tried it and it worked out instantly! Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
