damic Geschrieben February 25, 2022 at 17:17 Geschrieben February 25, 2022 at 17:17 We have 2 weight scales built with a 5 kg cell, a master brick 2.1 and a load cell bricklet 1.0 (first scale) and load cell bricklet 2.0 (second scale). The 2 scales worked perfectly well for a long time. But now, the Calibrate zero function in Brickviewer 2.4.18 does not work any more: the reading remains unchanged. Any clue to what has gone wrong? Zitieren
rtrbt Geschrieben February 28, 2022 at 08:57 Geschrieben February 28, 2022 at 08:57 Hi, Are you doing a full calibration, i.e. "Calibrate Zero" and "Calibrate Weight"? Also please update to the latest Brick Viewer version (2.4.21), maybe this is already fixed. Zitieren
damic Geschrieben March 17, 2022 at 19:21 Autor Geschrieben March 17, 2022 at 19:21 Thanks for your reply. Yes, I do complete calibration sequences. And no, updating BV to latest version did not fix the issue. I purchased all new scale parts with no success, hence I could not identify a faulty component. This is a real mystery because it did work before. On the other hand, it does not make the scale unusable, because taring before entering the Calibration function does the trick. Zitieren
