arthurPV Geschrieben December 1, 2021 at 11:35 Geschrieben December 1, 2021 at 11:35 Hello I have a problem when I disconnect and reconnect a Hall Effect Bricklet 2.0. After reconnecting, the bricklet is no longer accessible in Brick Viewer (not working in my own program neither). It is detected but when I go to the bricklet tab, I have this message "This bricklet is in booloader mode". This happens whether I disconnect the master brick USB or the 7-poles cable at the master brick side. The only way I found to get the bricklet back is to disconnect and reconnect the 7-poles cable at the bricklet side. This is not practical in my application since the bricklet is not accessible (requires substancial work to reach it) so I would need a more convenient fix for this problem. Ideally, the bricklet should still be funcitonnal after disconnecting and reconnecting the USB. If it is stuck in bootloader mode, there should be a way to reinitialize it without having to phyisically reach the bricklet connector. Is this problem a hardware issue with the bricklet I have? Or is it a repeatable problem? If so, do you have a suggestion for me to try? (hardware or software). Thank you for your help Arth Zitieren
borg Geschrieben December 1, 2021 at 13:14 Geschrieben December 1, 2021 at 13:14 This is very strange. There are a few ways a Bricklet can enter the bootloader mode: No firmware was flashed yet A new firmware flashing process is started The flashed firmware is wrong (wrong checksum, firmware of other Bricklet flashed or similar) The bootloader pad on the PCB is shorted The bootloader pad is the gold pad above the ".com" in this picture: Can you check that the pad is not shorted? Is it possible that there is some process running in the background that tries to flash a new firmware? Zitieren
RBBT Geschrieben December 11, 2021 at 15:08 Geschrieben December 11, 2021 at 15:08 (bearbeitet) Hi, I have the same problem with this Bricklet. It worked over a few hours without any problems. But today I come into the same troubles as arthurPV. I haven't started any firmware flashing or else. The Bricklet isn't damaged in any way (shortening a circuit or similar...). Removing the cable did not help. But removing from the magnet helps. My Bricklet is very close to a magnet before I startup. Do you have any solutions for this problem? Thanks in advance RBBT bearbeitet December 11, 2021 at 17:15 von RBBT Zitieren
borg Geschrieben December 13, 2021 at 09:28 Geschrieben December 13, 2021 at 09:28 Very strange, i can't explain how or why this could possibly happen. I will try to reproduce it. Currently i started a Hall Effect Bricklet 2.0 and just put a powerful magnet on top. Nothing has happened yet, i will wait a few hours now. Zitieren
borg Geschrieben December 14, 2021 at 14:34 Geschrieben December 14, 2021 at 14:34 It is currently still running without problems, i will leave it running for now. Is there anything else you guys are doing besides having a magnet permanently close to the Bricklet? Zitieren
RBBT Geschrieben December 15, 2021 at 14:43 Geschrieben December 15, 2021 at 14:43 Hi, I think that the problem resides in the HAT, but is erratic. My HAT is mounted on top of an raspi PI 4. HAT's configuration is like out of the box, I never changed anything. Firmware Version is 2.0.3. Raspi ist powered with an original Raspi power supply, HAT says 5.17Volt. On the HAT is connected: 1 Compass Bricklet 1 DC Bricklet 2.0 1 Hall Effect Bricklet 2.0 All Bricklets have the latest Firmware. All LED's are shining, NOT blinking. In the BrickViewer I pressed the "Sleep Now" Button on the HAT Brick Tab . After a few seconds the Hall Bricklet began blinking very hectical - not like hartbeat. but the other Bricklets not! They continue shining. The compass Bricklet works fine as before, but the Hall Bricklet Tab shows an "Flash" button. After the error I started my Java App, an this Exception was presented: Exception in thread "main" com.tinkerforge.TimeoutException: Did not receive response in time for function ID -1 at com.tinkerforge.DeviceBase.sendRequest(DeviceBase.java:225) at com.tinkerforge.DeviceBase.checkValidity(DeviceBase.java:175) at com.tinkerforge.BrickletCompass.setHeadingCallbackConfiguration(BrickletCompass.java:292) The Compass ist the first one that I connect. I tried this a few times again, but unfortunately the problem did not occur anymore. IMHO changes the HAT erratic into sleep mode, but why - I don't know. Hope this helps. Best Regards RBBT Zitieren
