Ahmed Geschrieben October 20, 2021 at 07:59 Geschrieben October 20, 2021 at 07:59 I'm working on a project for controlling Heater. As i used PID Controller the Output is Numeric I set the Range (0-100). Now the Solid State Relay can only get an ON/OFF Signal. what shall I do to transfer the PID output range to be a readable signal for the Relay? - As the output has to be Function in time. for example, (PID=0 output the SSR =0, PID Output = 10% relay has to be open for x seconds, ....) how can I initiate such a function using LABVIEW - OR are there any other options to get this Done? The system that I used is: "Master Brick connected with SSR Bricklet and Thermocouple Bricklet" Programmed using LabVIEW. Thanks Zitieren
