tf_archiv Geschrieben December 30, 2011 at 16:18 Geschrieben December 30, 2011 at 16:18 Hello, I tried to create some sample code before the actual parts arrived in Java, the library would not compile in java, please take a look at this -> http://stackoverflow.com/questions/8493925/java-netbeans-cannot-find-the-library-package Is it possible that the libraries are corrupt? Zitieren
tf_archiv Geschrieben December 30, 2011 at 16:18 Autor Geschrieben December 30, 2011 at 16:18 Indeed, I have the same problem, let me look into this. Edit: It should be OK now. The generator script that i use to generate the bindings and the .jar accidentially called javac on class files, the resulting exceptions made the .jar corrupt. Sorry for that. Zitieren
tf_archiv Geschrieben December 30, 2011 at 16:18 Autor Geschrieben December 30, 2011 at 16:18 No worries, just confused me a lot. Thanks! Zitieren
