Geschrieben (bearbeitet)
Hi everybody!
I'm working with a RS232 bricklet, connected to a weighing machine. I have to send a code to connect (S02) and ask for a measure (MSV?) to this device, but i don't receive responde with the value of the weight.
    rs232 = BrickletRS232(UID, ipcon) # Create device object
    rs232.write(*string_to_char_list('S02'))
    rs232.write(*string_to_char_list('MSV?'))
    time.sleep(1)
    buffer=rs232.read()
The value of buffer is always the same and the length of the message is 0, so i understand is not a valid response. I have tried adding the characters \ r \ n to the end of the string and the result is the same.
However from Brickviewer if I enter both codes in the input field (first S02, Intro and then MSV? and Intro again) I get a valid response with the correct measure.
What could be the problem?
Thank you very much and excuse my english
bearbeitet von astur80
Please try this example. I think the critical difference is the disable_read_callback() function call here. If you have the Brick Viewer tab for the RS232 Bricklet open, then the read callback is enable and the read() function call will return empty in that case. You should close Brick Viewer before testing this example.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
HOST = "localhost"
PORT = 4223
UID = "XYZ" # Change XYZ to the UID of your RS232 Bricklet
import time
from tinkerforge.bricklet_rs232 import BrickletRS232
# Convert string to char array with length 60, as needed by write
def string_to_char_list(message):
    chars = list(message)
    chars.extend(['\0']*(60 - len(message)))
    return chars, len(message)
# Assume that the message consists of ASCII characters and
# convert it from an array of chars to a string
def char_list_to_string(message, length):
    return ''.join(message[:length])
if __name__ == "__main__":
    # Ensure read callback is disabled, otherwise the read call will return empty
    rs232.disable_read_callback()
    # Send request
    rs232.write(*string_to_char_list('S02\r\n'))
    rs232.write(*string_to_char_list('MSV?\r\n'))
    # Wait for response
    time.sleep(1)
    # Read response
    message = char_list_to_string(*rs232.read())
    print('Message: ' + repr(message))
    ipcon.disconnect()
