Atak Geschrieben September 18, 2012 at 00:00 Geschrieben September 18, 2012 at 00:00 At the moment I only have the master brick, io16, breakout, and some sensors. I am wanting to control a couple servos I have laying around. This is the model of the servo...http://www.servocity.com/html/hs-311_standard.html I'll probably end up buying the DC brick later but until then, is there any way I could use the master brick to send pulses or anything? I'm pretty new to this stuff. I would be powering the servos with a separate battery pack. Zitieren
neomutant Geschrieben October 2, 2012 at 12:42 Geschrieben October 2, 2012 at 12:42 Hi, U need Servo brick its very easy to use. Zitieren
