Atak Geschrieben September 16, 2012 at 22:36 Geschrieben September 16, 2012 at 22:36 Ive been using parts with Python but now want to start playing with PHP. When I run the command "pear install Tinkerforge.tgz" I get this error... PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20090626+lfs/mysql.so' - /usr/lib/php5/20090626+lfs/mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20090626+lfs/mysqli.so' - /usr/lib/php5/20090626+lfs/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20090626+lfs/pdo_mysql.so' - /usr/lib/php5/20090626+lfs/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 Ignoring installed package __uri/Tinkerforge So does this mean I need to install MySql in order to use PHP with the bricks/bricklets? Zitieren
photron Geschrieben September 17, 2012 at 09:20 Geschrieben September 17, 2012 at 09:20 No, the PHP bindings don't require MySQL. The only requirement is that your PHP has the bcmath extension enabled. It seems to me that there's something wrong with either your PEAR or your PHP installation that leads to those errors about MySQL. Actually the "Ignoring installed package __uri/Tinkerforge" line tells you that the Tinkerforge PEAR package is already installed. At least PEAR thinks so. Try running pear list -c __uri to see what packages are already installed on the __uri channel. The Tinkerforge should be there. Then the PHP examples from the Tinkerforge PHP bindings zip should already work. Zitieren
Atak Geschrieben September 17, 2012 at 23:48 Autor Geschrieben September 17, 2012 at 23:48 I reinstalled MySQL and got it working. This is the output I get with that command... Installed packages, channel __uri: ================================== Package Version State Tinkerforge 1.0.11 stable Now, when I open the page ExampleCallback.php which I have placed on my Apache server, it does nothing but display a blank page. My host, port, and uid are correct... $host = 'localhost'; $port = 4223; $uid = '5Jj'; // Change to your UID I've played around with these settings within the PHP file... require_once('Tinkerforge/IPConnection.php'); require_once('Tinkerforge/BrickletAmbientLight.php'); use Tinkerforge\IPConnection; use Tinkerforge\BrickletAmbientLight; I'm thinking my problem may be permissions or something? or something to do with the ports? I have run this command to set permissions... find . -type f -exec chmod 644 {} \; && find . -type d -exec chmod 755 {} \; Zitieren
photron Geschrieben September 18, 2012 at 07:58 Geschrieben September 18, 2012 at 07:58 Before trying it in Apache you should try it on the command line with the php commandline tool. Do other PEAR installed packages work within Apache? Maybe its a problem with your PEAR setup. You could try to enable all the error reporting for PHP so that Apache shows possible errors. You should also have a look at the Apache logs for possible hints. Zitieren
