Dodo Geschrieben August 17, 2021 at 17:49 Geschrieben August 17, 2021 at 17:49 Hello, i want ask more about error characteristics of measurement noise(current measurement), do you know, what is the value of the noise variance? Did you do some tests? Because i need variance in my Klaman filter project. Thanks. Zitieren
borg Geschrieben August 18, 2021 at 11:24 Geschrieben August 18, 2021 at 11:24 The calibration and testing of the Bricklet is done with an electronic load together with a Agilent U1273A. We don't measure noise. You can take a look at the typical characteristics that TI has in the datasheet of the INA226: https://raw.githubusercontent.com/Tinkerforge/voltage-current-v2-bricklet/master/datasheets/ina226.pdf Not sure if that helps at all? 1 Zitieren
Dodo Geschrieben August 18, 2021 at 13:41 Autor Geschrieben August 18, 2021 at 13:41 thank you! for sure it is helpful!!! Zitieren
