Voltage/Current Bricklet 2.0 It is possible to connect with Arduino?
Hey guys,
I'm using Voltage/Current Bricklet 2.0 in my project basic on Arduino....... So it is possible to connect with arduino. just ignore hardware connection, which Example should i look for to port into arduino platform!!!
Thank you!!!!
This is indeed possible with the C/C++ bindings for microcontrollers. However those are not finished yet. You can find the latest beta here :
Documentation is available here: https://www.tinkerforge.com/en/doc/Software/API_Bindings_uC.html and here for the Voltage/Current Bricklet 2.0: https://www.tinkerforge.com/en/doc/Software/Bricklets/VoltageCurrentV2_Bricklet_uC.html
Links to the Bricklet-specific documentation are not generated yet, however you can use the documentation for the "normal" C bindings and then add a u before the last C like this:
https://www.tinkerforge.com/en/doc/Software/Bricklets/AirQuality_Bricklet_C.html
becomes
https://www.tinkerforge.com/en/doc/Software/Bricklets/AirQuality_Bricklet_uC.html
I'm trying use that library with the C/C++ bindings for microcontrollers in F429 plattform. i saw that code, it used two spi with code select, But i have only use one Bricklet, this is not necessary to use 2 spi? Can i just change the code with one SPI or ?  but it seems like, so much changes in the code......
You are using the STM32F0-HAL? It looks like the HAL only initializes the SPI peripherals that are configured to be used. So if you only use SPI0_INSTANCE or SPI1_INSTANCE in your port configuration, the other one should be left unmodified.
