Hello,
Has anyone been able to use the StepperBrick (or SSB) with the Clearpath Teknic Motors?
https://www.teknic.com/model-info/CPM-SDSK-2310D-RLN
The reason I ask is that these motor have a built-in encoder/driver so I just need to send data signals (steps) to the motors. The motor receive a direct power from a 24vdc power source so the SD/SSD only need to send the data signals?
Any help is appreciated,
Thanks,
Shaffin.
Geschrieben (bearbeitet)
Hello Borg,
Can you please explain how that would work?
Are you suggesting that using the industrial-digital-out bricklet (paired with a master brick), and generate the pulses manually to drive the step and direction?
Or can the pulses coming from the SB/SSB be directed to the industrial-digital-out bricklet?
Thanks,
Shaffin.
bearbeitet von shaffin
