Anton Geschrieben August 21, 2012 at 19:18 Share Geschrieben August 21, 2012 at 19:18 Hi, My DC brick has stopped working i am no longer able to connect and the leds are not turning on. I've noticed recently that it gets very hot. At the moment i'm not using it to control a motor, i'm only using it for the extra bricklet connections. The place where it gets very hot is right on the Atmel chip. I've tried to put it in boot loader mode, but so far i haven't been successful. So do you think that it is fried somehow and the brick is lost or is there anything i can do to try and fix it? Thanks. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
batti Geschrieben August 22, 2012 at 07:40 Share Geschrieben August 22, 2012 at 07:40 Hi Anton, it is very hard to tell what the problem is. Maybe it's a problem with the driver IC. Please contact us via email. Thanks, Bastian Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
