guppi Geschrieben May 28, 2021 at 10:09 Geschrieben May 28, 2021 at 10:09 Hello I dont know how to read the Error out of the Program ich tried this. ErrorLog = can.get_error_log() print(str(ErrorLog)) the answer is this: ErrorLoG: ErrorLog(transceiver_state=0, transceiver_write_error_level=0, transceiver_read_error_level=0, transceiver_stuffing_error_count=0, transceiver_format_error_count=0, transceiver_ack_error_count=0, transceiver_bit1_error_count=197, transceiver_bit0_error_count=0, transceiver_crc_error_count=0, write_buffer_timeout_error_count=0, read_buffer_overflow_error_count=0, read_buffer_overflow_error_occurred=(False, False), read_backlog_overflow_error_count=0) Press key to exit When i have an Error on the CAN Brick V2 (Red LED is on), i want to reset the Brick or if anyboday has an idear how to solve this? If i have an erroe i tried this: HOST = "localhost" PORT = 4223 UID_can = "can" # Change XYZ to the UID of your CAN In Bricklet 2.0 from tinkerforge.bricklet_can_v2 import BrickletCANV2 from tinkerforge.ip_connection import IPConnection ipcon = IPConnection() # Create IP connection can = BrickletCANV2(UID_can, ipcon) Reset = can.reset() HOST = "localhost" PORT = 4223 UID_can = "can" # Change XYZ to the UID of your CAN In Bricklet 2.0 from tinkerforge.bricklet_can_v2 import BrickletCANV2 from tinkerforge.ip_connection import IPConnection ipcon = IPConnection() # Create IP connection can = BrickletCANV2(UID_can, ipcon) But i get an Error (I deletet my folder ;)): Traceback (most recent call last): File "C:/Users/.../ErrorLogTest.py", line 8, in <module> Reset = can.reset() File "C:/Users/...\tinkerforge\bricklet_can_v2.py", line 697, in reset self.check_validity() File "C:/Users/...\tinkerforge\ip_connection.py", line 506, in check_validity device_identifier = self.ipcon.send_request(self, 255, (), '', 33, '8s 8s c 3B 3B H')[5] # <device>.get_identity File "C:/Users/...\tinkerforge\ip_connection.py", line 1302, in send_request self.send(request) File "C:/Users/...\tinkerforge\ip_connection.py", line 1274, in send raise Error(Error.NOT_CONNECTED, 'Not connected') tinkerforge.ip_connection.Error: Not connected (-8) So anybody can help me with this problem? Zitieren
photron Geschrieben August 24, 2021 at 11:21 Geschrieben August 24, 2021 at 11:21 As the "Not connected" error indicates, you didn't connect the IP Connection. Take a look at any of our Python examples. Before the can.reset() call you have to call ipcon.connect(HOST, PORT). But you should figure out where the bit1 errors are coming from. Double check you electrical CAN bus connection. Did you mix up CAN-low and CAN-high? Also, your post seem to be from May 28 2021, but you seem to have registered your account on August 23 2021 (yesterday). This is confusing me. Zitieren
