Hello I dont know how to read the Error out of the Program ich tried this.
ErrorLog = can.get_error_log()
print(str(ErrorLog))
the answer is this:
ErrorLoG:
ErrorLog(transceiver_state=0, transceiver_write_error_level=0, transceiver_read_error_level=0, transceiver_stuffing_error_count=0, transceiver_format_error_count=0, transceiver_ack_error_count=0, transceiver_bit1_error_count=197, transceiver_bit0_error_count=0, transceiver_crc_error_count=0, write_buffer_timeout_error_count=0, read_buffer_overflow_error_count=0, read_buffer_overflow_error_occurred=(False, False), read_backlog_overflow_error_count=0)
Press key to exit
When i have an Error on the CAN Brick V2 (Red LED is on), i want to reset the Brick or if anyboday has an idear how to solve this?
If i have an erroe i tried this:
HOST = "localhost"
PORT = 4223
UID_can = "can"     # Change XYZ to the UID of your CAN In Bricklet 2.0
from tinkerforge.bricklet_can_v2 import BrickletCANV2
can = BrickletCANV2(UID_can, ipcon)
Reset = can.reset()
HOST = "localhost"
PORT = 4223
But i get an Error (I deletet my folder ;)):
  File "C:/Users/.../ErrorLogTest.py", line 8, in <module>
    Reset = can.reset()
  File "C:/Users/...\tinkerforge\bricklet_can_v2.py", line 697, in reset
    self.check_validity()
  File "C:/Users/...\tinkerforge\ip_connection.py", line 506, in check_validity
    device_identifier = self.ipcon.send_request(self, 255, (), '', 33, '8s 8s c 3B 3B H')[5] # <device>.get_identity
  File "C:/Users/...\tinkerforge\ip_connection.py", line 1302, in send_request
    self.send(request)
  File "C:/Users/...\tinkerforge\ip_connection.py", line 1274, in send
    raise Error(Error.NOT_CONNECTED, 'Not connected')
tinkerforge.ip_connection.Error: Not connected (-8)
So anybody can help me with this problem?
  • 2 months later...
As the "Not connected" error indicates, you didn't connect the IP Connection. Take a look at any of our Python examples. Before the can.reset() call you have to call ipcon.connect(HOST, PORT).
But you should figure out where the bit1 errors are coming from. Double check you electrical CAN bus connection. Did you mix up CAN-low and CAN-high?
Also, your post seem to be from May 28 2021, but you seem to have registered your account on August 23 2021 (yesterday). This is confusing me.
