DrWino Geschrieben May 22, 2021 at 18:08 Geschrieben May 22, 2021 at 18:08 I have a IMU2 with ethernet brick + master brick. I want to connect directly to just the IMU2 over USB. I use python but I cannot find an example with USB connection. Everything is IP. Can you helps? Zitieren
rtrbt Geschrieben May 25, 2021 at 07:39 Geschrieben May 25, 2021 at 07:39 Hi, To use any Brick over USB, you have to install Brick Daemon on the connected PC. You can then connect to the daemon over TCP/IP (i.e. use localhost if you run your Python script on the same PC). Zitieren
