Dodo Geschrieben May 11, 2021 at 13:36 Geschrieben May 11, 2021 at 13:36 Hello, I dowloaded some example files,but i couldn't find like #include "xmc_spi.h" #include "xmc_device.h" #include "xmc_gpio.h" what are kinds of files, where can i find them? Thank you. Zitieren
photron Geschrieben May 11, 2021 at 14:24 Geschrieben May 11, 2021 at 14:24 I think you mistook the firmware source code of the Voltage/Current Bricklet 2.0 as example code. I assume you don't want to modify the firmware of the Bricklet, but you want to use the Bricklet as is. You can find the C/C++ examples for the Voltage/Current Bricklet 2.0 here as part of the API documentation: https://www.tinkerforge.com/en/doc/Software/Bricklets/VoltageCurrentV2_Bricklet_C.html or here on GitHub: https://github.com/Tinkerforge/voltage-current-v2-bricklet/tree/master/software/examples/c You'll need the C/C++ API bindings to compile the examples: https://download.tinkerforge.com/bindings/c/tinkerforge_c_bindings_2_1_32.zip The ZIP also contains the C/C++ examples for the Voltage/Current Bricklet 2.0 at examples/bricklet/voltage_current_v2. Zitieren
Dodo Geschrieben May 12, 2021 at 05:30 Autor Geschrieben May 12, 2021 at 05:30 achso, thank you so much!!!!!! Zitieren
