Anton Geschrieben August 9, 2012 at 19:10 Geschrieben August 9, 2012 at 19:10 Hi, The Brick Viewer can't find the serial port. I'm not quite sure what to do about it. I'm running Max Os 10.8 and 10.7 And the latest BrickV and BrickD Is there any way to take the Master Brick out of Bootloader mode? Any suggestions? regards, Zitieren
Anton Geschrieben August 9, 2012 at 20:21 Autor Geschrieben August 9, 2012 at 20:21 It works! Waited a while and suddenly the proper serial port showed up in the menu. Zitieren
