Superp Geschrieben January 28, 2021 at 08:26 Geschrieben January 28, 2021 at 08:26 Hello, I have an NFC Bricklet that is factory new: it has only been accessed through Brickv to do some test scans. When I call #get_detection_led_config it returns 4. That value is not in the documentation. What does '4' mean? Zitieren
borg Geschrieben January 28, 2021 at 10:32 Geschrieben January 28, 2021 at 10:32 Oh, indeed. I looked at the source code and there is some mixup internaly between the status and detection LED. I will fix this with a firmware update. Zitieren
borg Geschrieben January 28, 2021 at 10:57 Geschrieben January 28, 2021 at 10:57 Should now be fixed in 2.0.5 Zitieren
Superp Geschrieben January 28, 2021 at 11:27 Autor Geschrieben January 28, 2021 at 11:27 Fixed. Zitieren
