Superp Geschrieben December 1, 2020 at 10:46 Share Geschrieben December 1, 2020 at 10:46 (bearbeitet) Hello, I have a question about discovery of devices with Ruby. Enumeration supplies the numeric device_identifier for each device, for instance 2103 for a 'LED Strip Bricklet 2.0'. See documentation. Next steps would be to load the file defining the matching class, and to initialize an instance of that class: require 'tinkerforge/bricklet_led_strip_v2' Tinkerforge::BrickletLEDStripV2.new ... In other words, I need the name of the matching class for a '2103 device' and the file which defines that class. Tinkerforge::DEVICE_DISPLAY_NAMES only maps device_identifier to device_display_name. How do I map numeric device_identifier to class and file? One way would be to load all 139 device classes, and than loop through all Tinkerforge::Device descendants until I find the one with the matching DEVICE_IDENTIFIER constant. That sounds like a really bad idea. Has anyone figured this out yet? bearbeitet December 1, 2020 at 10:55 von Superp a %#@& typo Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben December 1, 2020 at 18:34 Share Geschrieben December 1, 2020 at 18:34 Tinkerforge::DEVICE_DISPLAY_NAMES is internal for error message purposes. What you're looking for is a device factory. The Ruby bindings don't have that. 7 hours ago, Superp said: One way would be to load all 139 device classes, and than loop through all Tinkerforge::Device descendants until I find the one with the matching DEVICE_IDENTIFIER constant. That sounds like a really bad idea. That's not a bad idea at all, that basically how Brick Viewer solves this problem. But instead of doing a linear search, Brick Viewer builds a dictionary that maps device identifier to device class and then uses that dictionary to do the lookup efficiently. What are you trying to build that requires a device factory? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Superp Geschrieben December 1, 2020 at 21:00 Autor Share Geschrieben December 1, 2020 at 21:00 Hi Photron, Thanks for responding. I am basically just a lazy programmer who likes magic. What I have done so far is write a little bit of Ruby that 1) takes stock of Device descendants. 2) requires one of TF's source-files. 3) takes stock again and compares to (1) to identify any newly defined class. 4) gets DEVICE_IDENTIFIER and DEVICE_DISPLAY_NAME from the newly defined class. 5) Repeats for all source-files. This generates a device_info.txt which maps device_identifier, device class, source-file, and device_display_name. You can use any of these four to look up the other three. This is my third week of using TF and I hope to make it part of a fairly big project. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Superp Geschrieben December 9, 2020 at 10:15 Autor Share Geschrieben December 9, 2020 at 10:15 So, I think I found a working solution, which I'll share here in case anyone else runs into the same limitation. Tinkerforge.device_info 2103 => [2103, "LED Strip Bricklet 2.0", ["Tinkerforge::BrickletLEDStripV2", "bricklet_led_strip_v2"]] and my_devices = Tinkerforge.connect.discover Source here. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
