bugra_s Geschrieben October 27, 2020 at 15:31 Geschrieben October 27, 2020 at 15:31 Hello, I have a Pi 4 which is connected to a Pi zero hat. The Pi zero hat is then connected to a isolator bricklet which is connected to a analog out v3 bricklet. Unfortunately the maximum voltage the AnalogOutV3 can operate isn't sufficient for me. Is there any way to raise the maximum voltage to 24V or even more (ie. connecting two analogoutV3 bricklets in serial?)? Thank you Zitieren
