Viktor Geschrieben October 14, 2020 at 10:32 Share Geschrieben October 14, 2020 at 10:32 I am using the IMU 2.0 in visual c++. When I run the example code "example_simple.c" in visual studio, it says I am missing the link tot he library functions. I was not able to find any lib file in the source directory. 1>main.obj : error LNK2019: unresolved external symbol _ipcon_create referenced in function _main 1>main.obj : error LNK2019: unresolved external symbol _ipcon_destroy referenced in function _main 1>main.obj : error LNK2019: unresolved external symbol _ipcon_connect referenced in function _main 1>main.obj : error LNK2019: unresolved external symbol _imu_v2_create referenced in function _main 1>main.obj : error LNK2019: unresolved external symbol _imu_v2_destroy referenced in function _main 1>main.obj : error LNK2019: unresolved external symbol _imu_v2_get_quaternion referenced in function _main Thanks for the help. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Backdraft007 Geschrieben October 14, 2020 at 10:50 Share Geschrieben October 14, 2020 at 10:50 Hi, did you follow this instructions?https://www.tinkerforge.com/en/doc/Software/API_Bindings_C.html Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben October 14, 2020 at 11:35 Share Geschrieben October 14, 2020 at 11:35 There is not precompiled library you could link against. You need to include ip_connection.c and brick_imu_v2.c from the API bindings into your Visual Studio project, as the documentation explains. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Viktor Geschrieben October 15, 2020 at 09:33 Autor Share Geschrieben October 15, 2020 at 09:33 Thanks guys. Got it working. Missed the source files. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
