mylo0001 Geschrieben September 25, 2020 at 21:20 Geschrieben September 25, 2020 at 21:20 Hello, I am using a Thermal Imaging Bricklet to create thermal images. My question is general, but I wanted to know on which formula the generated color palette is based and what's the logic behind it? For example in python the color palette creation looks as follows: for x in range(256): x /= 255.0 palette.append(int(round(255*math.sqrt(x)))) # RED palette.append(int(round(255*pow(x, 3)))) # GREEN if math.sin(2 * math.pi * x) >= 0: palette.append(int(round(255*math.sin(2 * math.pi * x)))) # BLUE else: palette.append(0) return palette Source: https://www.tinkerforge.com/en/doc/Software/Bricklets/ThermalImaging_Bricklet_Python.html Does any one know what's the principal behind this color palette? Thank you! Zitieren
rtrbt Geschrieben September 28, 2020 at 11:57 Geschrieben September 28, 2020 at 11:57 Hi, The palette is gnuplot's PM3D palette. It looks similar to the palettes used by FLIR. https://stackoverflow.com/questions/28495390/thermal-imaging-palette has further explainations. 1 Zitieren
mylo0001 Geschrieben September 29, 2020 at 23:04 Autor Geschrieben September 29, 2020 at 23:04 Okay, thank you very much for your reply, I will look it up! Zitieren
