heute morgen erschien folgendes DeskFenster auf einem meiner 4er Raspis. Dieser hat per VNC/LAN Zugriff auf den Pi an dem meine Sensoren hängen  :
<Brick Viewer 2.4.13 on Raspbian GNU/Linux 10 (buster) (linux 5.4.51-v7l+) (PyQt 5.11.3, Qt 5.11.3)
Exception raised at 2020-08-10T05:12:20.380962+02:00
  File "/usr/share/brickv/firmware_fetch.py", line 283, in run
    new_data = fetch_latest_fw_versions(self.fw_versions_avail.emit)
  File "/usr/share/brickv/firmware_fetch.py", line 204, in fetch_latest_fw_versions
    with urlopen(LATEST_VERSIONS_URL, timeout=10) as response:
  File "/usr/share/brickv/urlopen.py", line 39, in urlopen
    return urllib.request.urlopen(*args, **kwargs, context=context)
  File "/usr/lib/python3.7/urllib/request.py", line 222, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/lib/python3.7/urllib/request.py", line 525, in open
    response = self._open(req, data)
  File "/usr/lib/python3.7/urllib/request.py", line 543, in _open
    '_open', req)
  File "/usr/lib/python3.7/urllib/request.py", line 503, in _call_chain
    result = func(*args)
  File "/usr/lib/python3.7/urllib/request.py", line 1360, in https_open
    context=self._context, check_hostname=self._check_hostname)
  File "/usr/lib/python3.7/urllib/request.py", line 1317, in do_open
    encode_chunked=req.has_header('Transfer-encoding'))
  File "/usr/lib/python3.7/http/client.py", line 1244, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/lib/python3.7/http/client.py", line 1290, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.7/http/client.py", line 1239, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.7/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/lib/python3.7/http/client.py", line 966, in send
    self.connect()
  File "/usr/lib/python3.7/http/client.py", line 1399, in connect
    super().connect()
  File "/usr/lib/python3.7/http/client.py", line 938, in connect
    (self.host,self.port), self.timeout, self.source_address)
  File "/usr/lib/python3.7/socket.py", line 707, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
  File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe4 in position 6: invalid continuation byte
Active Threads:
Thread 2673730656 (Name: Thread-66495):
  File "/usr/lib/python3.7/threading.py", line 885, in _bootstrap
    self._bootstrap_inner()
  File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
    self.run()
  File "/usr/share/brickv/main.py", line 118, in run_with_except_hook
    run_old(*args, **kw)
  File "/usr/lib/python3.7/threading.py", line 1164, in run
    self.finished.wait(self.interval)
  File "/usr/lib/python3.7/threading.py", line 552, in wait
    signaled = self._cond.wait(timeout)
  File "/usr/lib/python3.7/threading.py", line 300, in wait
    gotit = waiter.acquire(True, timeout)
Thread 2648552544 (Name: Thread-66494):
    self.run()
Thread 2564994144 (Name: Thread-66493):
    self.run()
Thread 2732479584 (Name: Thread-66492):
    self.run()
Thread 2792350816 (Name: Thread-66491):
    self.run()
Thread 2573386848 (Name: Thread-66490):
    self.run()
Thread 2767172704 (Name: Thread-66489):
    self.run()
Thread 2556601440 (Name: Thread-66488):
    self.run()
Thread 2724086880 (Name: Thread-66487):
    self.run()
Thread 2775565408 (Name: Thread-66486):
    self.run()
Thread 2665337952 (Name: Thread-66485):
    self.run()
Thread 2682123360 (Name: Thread-66484):
    self.run()
Thread 2690516064 (Name: Thread-66483):
    self.run()
Thread 2623743072 (Name: Thread-66482):
    self.run()
Thread 2811229280 (Name: GuiData-Writer):
    self.run()
  File "/usr/lib/python3.7/threading.py", line 865, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/share/brickv/data_logger/job.py", line 150, in _job
    time.sleep(self._datalogger.job_sleep)
Thread 2606957664 (Name: CSV-Writer):
    self.run()
  File "/usr/share/brickv/data_logger/job.py", line 100, in _job
Thread 2800743520 (Name: Brickd-Receiver):
    self.run()
  File "/usr/share/brickv/bindings/ip_connection.py", line 1019, in receive_loop
    data = self.socket.recv(8192)
Thread 2715694176 (Name: Disconnect-Prober):
    self.run()
  File "/usr/share/brickv/bindings/ip_connection.py", line 1249, in disconnect_probe_loop
    disconnect_probe_queue.get(True, IPConnection.DISCONNECT_PROBE_INTERVAL)
  File "/usr/lib/python3.7/queue.py", line 179, in get
    self.not_empty.wait(remaining)
Thread 2758780000 (Name: Callback-Processor):
    self.run()
  File "/usr/share/brickv/bindings/ip_connection.py", line 1226, in callback_loop
    kind, data = callback.queue.get()
  File "/usr/lib/python3.7/queue.py", line 170, in get
    self.not_empty.wait()
  File "/usr/lib/python3.7/threading.py", line 296, in wait
    waiter.acquire()
Thread 2783958112 (Name: Brickd-Receiver):
    self.run()
Thread 2632135776 (Name: Disconnect-Prober):
    self.run()
Thread 2615350368 (Name: Callback-Processor):
    self.run()
    waiter.acquire()
Thread 2740872288 (Name: Brickd-Receiver):
    self.run()
Thread 2707301472 (Name: Disconnect-Prober):
    self.run()
Thread 2749264992 (Name: Callback-Processor):
    self.run()
    waiter.acquire()
Thread 2844607584 (Name: Dummy-2):
  File "/usr/share/brickv/async_call.py", line 128, in run
    ac = async_call_queue.get()
    waiter.acquire()
Thread 2979869792 (Name: Thread-1):
    self.run()
  File "/usr/share/brickv/main.py", line 193, in error_spawner
    report_message = prefix + '\n\n' + error + '\nActive Threads:\n\n' + '\n\n'.join(self.get_python_thread_stack_traces())
  File "/usr/share/brickv/main.py", line 137, in get_python_thread_stack_traces
    stack_trace = ''.join(traceback.format_stack(stack))
Thread 3069237968 (Name: MainThread):
  File "/usr/share/brickv/main.py", line 364, in <module>
    main()
  File "/usr/share/brickv/main.py", line 361, in main
    sys.exit(brick_viewer.exec_())
Was möchte der BV nun damit sagen (denn er läuft ohne Probs weiter bzw. zeigt er die Daten des anderen PI) ?
Das folgende DEBUG log stammt von dem Pi der via VNC Zugriff hat (da hängt ne 500 GB SSD dran, von der dieser Pi auch booted. PlatzProbs sollten also nicht vorhanden sein):
<2020-08-09 02:42:52 - INFO - Connection to 192.168.178.38:4223 established.
2020-08-09 02:42:52 - DEBUG - Set ipcon.time_out to 1.
2020-08-09 02:42:52 - INFO - Logging data to CSV file: /home/pi/logger_data_1595682863.csv
2020-08-09 02:42:52 - DEBUG - [devices:Outdoor Weather Bricklet]
2020-08-09 02:42:52 - DEBUG - [devices:Air Quality Bricklet]
2020-08-09 02:42:52 - DEBUG - [devices:Ambient Light Bricklet 3.0]
2020-08-09 02:42:52 - DEBUG - [devices:CO2 Bricklet 2.0]
2020-08-09 02:42:52 - DEBUG - [devices:GPS Bricklet 2.0]
2020-08-09 02:42:52 - DEBUG - [devices:UV Light Bricklet 2.0]
2020-08-09 02:42:52 - DEBUG - Applying options for "Air Quality Bricklet" with UID "LgD"
2020-08-09 02:42:52 - DEBUG - Applying options for "Ambient Light Bricklet 3.0" with UID "L2t"
2020-08-09 02:42:52 - DEBUG - Applying options for "UV Light Bricklet 2.0" with UID "GNP"
2020-08-09 02:42:52 - DEBUG - Jobs started.
2020-08-09 02:42:52 - DEBUG - Get-Timers started.
2020-08-09 02:42:52 - INFO - DataLogger is running...
2020-08-09 02:42:52 - DEBUG - [Job:CSV-Writer] Started
2020-08-09 02:42:52 - DEBUG - [Job:GuiData-Writer] Started >
auch nicht sehr Aussage fähig.
Irgend welche Hinweise/Tips
cu
Brick Viewer fragt auf tinkerforge.com die Liste der aktuellen Firmware Versionen ab, um Updates anzeigen zu können. Bei dieser Abfrage ist ein Übertragungsfehler aufgetreten, der im Code nicht behandelt wurde. Unbehandelt Fehler landen dann in diesem Fehlermeldungsdialog.
Das hat nichts damit zu tun was du zu dem Zeitpunkt getan hast. So richtig erklären kann in den speziellen Fehler nicht. Da hatte entweder unser Server oder deine Internetverbindung gerade Schluckauf.
Trat der Fehler nur einmal auf, oder tritt der immer wieder auf?
In der nächste Brick Viewer wird dieser Fehler richtig behandelt werden.
also zumindest in den Logs meines Kabel Modems findet sich da nichts was auf einen Verbindungsfehler/Abbruch hinweisen könnte.
Der BV Fehler bzw. die Meldung erschien bis dato auch nur dieses eine Mal. Wie lautet den die genaue Domain die der BV bei Update Abfragen verwendet ?
Einfach nur "tinkerforge.com" ?
Eventuell blockt da ja auch Pihole etwas seit dem Update auf v5.2 ? Allerdings finde ich da hier auch nichts in den QueryLogs zu.
Komisch ist jetzt aktuell auch, das der BV beim manuellem Auslösen einer Update Suche nix mehr anzeigt (normalerweise erscheint dann ja ein Popup) -
alles sehr seltsam.....
Cu
