set spotmeter config
I am using thermal sensor and HAT Zero with Raaspberry Pi. I wanted to set ROI from my python script to get temperature. I have tried setting the ROI using ti.set_spotmeter_config(first_column=20, first_row = 20, last_column = 40, last_row = 40).  It is giving me this kind of error.
    TypeError: set_spotmeter_config() takes 2 positional arguments but 5 were given
How can I resolve this error?
code:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Shows live thermal image video in Tk window
HOST = "localhost"
PORT = 4223
UID = "LcZ" # Change XYZ to the UID of your Thermal Imaging Bricklet
from tinkerforge.bricklet_thermal_imaging import BrickletThermalImaging
import math
import time
try:
    from Tkinter import Tk, Canvas, PhotoImage, mainloop, Label # Python 2
    from Queue import Queue, Empty
except:
    from tkinter import Tk, Canvas, PhotoImage, mainloop, Label # Python 3
    from queue import Queue, Empty
from PIL import Image, ImageTk
WIDTH  = 80
HEIGHT = 60
SCALE  = 10 # Use scale 5 for 400x300 window size (change for different size). Use scale -1 for maximized mode
image_queue = Queue()
# Creates standard thermal image color palette (blue=cold, red=hot)
def get_thermal_image_color_palette():
    palette = []
    for x in range(256):
        x /= 255.0
        palette.append(int(round(255*math.sqrt(x))))                  # RED
        palette.append(int(round(255*pow(x, 3))))                     # GREEN
        if math.sin(2 * math.pi * x) >= 0:
            palette.append(int(round(255*math.sin(2 * math.pi * x)))) # BLUE
        else:
            palette.append(0)
    return palette
# Callback function for high contrast image
def cb_high_contrast_image(image):
    # Save image to queue (for loop below)
    global image_queue
    image_queue.put(image)
def on_closing(window, exit_queue):
    exit_queue.put(True)
if __name__ == "__main__":
    ti = BrickletThermalImaging(UID, ipcon) # Create device object
    print (ti.get_spotmeter_config())
    ti.set_spotmeter_config(20,20,40,40)
    # Register illuminance callback to function cb_high_contrast_image
    ti.register_callback(ti.CALLBACK_HIGH_CONTRAST_IMAGE, cb_high_contrast_image)
    # Enable high contrast image transfer for callback
    ti.set_image_transfer_config(ti.IMAGE_TRANSFER_CALLBACK_HIGH_CONTRAST_IMAGE)
    # Create Tk window and label
    window = Tk()
    # Run maximized
    if SCALE == -1:
        window.geometry("%dx%d+0+0" % (window.winfo_screenwidth(), window.winfo_screenheight()))
        window.update() # Update to resize the window
        w, h = window.winfo_width(), window.winfo_height()
        SCALE = min(w // WIDTH, h // HEIGHT)
    label = Label(window)
    label.pack()
    image = Image.new('P', (WIDTH, HEIGHT))
    # This puts a color palette into place, if you
    # remove this line you will get a greyscale image.
    image.putpalette(get_thermal_image_color_palette())
    #ti.set_spotmeter_config(120,310,360,510)
    exit_queue = Queue()
    window.protocol("WM_DELETE_WINDOW", lambda: on_closing(window, exit_queue))
    while True:
        try:
            exit_queue.get_nowait()
            break # If the exit_queue is not empty, the window was closed.
        except Empty:
            pass
        # Get image from queue (blocks as long as no data available)
        image_data = image_queue.get(True)
        # Use original width/height to put data and resize again afterwards
        image = image.resize((WIDTH, HEIGHT))
        image.putdata(image_data)
        image = image.resize((WIDTH*SCALE, HEIGHT*SCALE), Image.ANTIALIAS)
        # Translate PIL Image to Tk PhotoImageShow and show as label
        photo_image = ImageTk.PhotoImage(image)
        label.configure(image=photo_image)
        y = ti.get_statistics()
        z = ((y[0][1]*655)/65535)- 273
        print (z)
        window.update()
    window.destroy()
