rtrbt Geschrieben July 6, 2020 at 10:54 Geschrieben July 6, 2020 at 10:54 ATTENTION: Arduinos with an AVR microcontroller (for example the Arduino Uno or Mega) use a logic level of 5V. Bricklets use a logic level of 3.3V. A level shifter is required between the Arduino and any bricklet. Edit: Here's the official documentation. Hi, After multiple customer requests to be able to control Bricklets directly with a microcontroller, I've spent the last months creating bindings to be able to do so. The first beta version of the C/C++ bindings for microcontrollers are attached to this post. With them you can control Co-processor bricklets using for example an Arduino over SPI. The bindings are separated in a common implementation and Hardware Abstraction Layers (HALs) for the specific platforms. At this time a HAL for Arduino AVR and ESP32 boards and a HAL for the Raspberry Pi (Zero) with a Hat (Zero) Brick are available. Further information about the interface of the bindings, and on how to implement custom HALs for other boards can be found in the documentation. In the future there will be additional hardware for the bindings: An ESP32 based board on that programs using the bindings can be executed, as well as a new Breakout board that allows connecting multiple Bricklets to a micro controller. Cheers, Erik Edit: Beta 8 with the following change: Fixed a bug where callbacks stopped working after 35 minutes This will probably be the last beta version. However the beta phase will continue until the hardware for the bindings is released. tinkerforge_uc_bindings_2_0_0_beta_8.zip Zitieren
