shaffin Geschrieben June 1, 2020 at 14:42 Geschrieben June 1, 2020 at 14:42 Hello, I have a SIlent StepperBrick that I plug into a USB port under Win10 and it is not being recognized. I tried a second one, and same results! Has anyone come across this? Sam. Zitieren
Backdraft007 Geschrieben June 2, 2020 at 06:36 Geschrieben June 2, 2020 at 06:36 Hi, do you have installed Brick Daemon and Brick Viewer? Greets Chris Zitieren
shaffin Geschrieben June 2, 2020 at 19:13 Autor Geschrieben June 2, 2020 at 19:13 Yes, I do....normally when I plug in the USB, Win10 starts recognizing and installing the driver. Then I install the BrickD and BrickV. But in this case Win10 does not recognize anything when I plugin the USB cord with the SSB attached 😞 Zitieren
photron Geschrieben June 3, 2020 at 08:10 Geschrieben June 3, 2020 at 08:10 Did the Bricks work before, or did you just receive them and they have never worked for you? Pleas check for bend pins in the Bricklet ports of the Bricks: https://www.tinkerforge.com/en/doc/_images/bricklet_connector_short_circuit.jpg Does the blue LED on the Brick light up when you plug in the Brick? If not, does a new serial port show up in Windows Device Manager? If yes, then the Brick is in bootloader and you can use Brick Viewer to flash the firmware to it to make it work again: https://www.tinkerforge.com/en/doc/Software/Brickv.html#serial-port If that's no the problem then did you try another USB cable or another USB port on your PC, just to double check that not the USB cable or USB port causes this. Zitieren
