Ravi Geschrieben May 19, 2020 at 11:24 Share Geschrieben May 19, 2020 at 11:24 Dear Sir/Madam. We just bought thermal camera from you. It came without any cable connection. We want to buy cable to connect the camera with Raspberry Pi. Can you please suggest any cable to connect it with Raspberry Pi? Kind Regards, Ravi Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
rtrbt Geschrieben May 19, 2020 at 12:05 Share Geschrieben May 19, 2020 at 12:05 Hi Ravi, If the GPIO pins on your Raspberry Pi are not occupied yet, you can connect the Thermal Imaging Bricklet with either a HAT Brick or HAT Zero Brick and a 7p-7p cable of any length. If the GPIO pins are occupied, you need a Master Brick and a 7p-10p cable. Cables are available here. Erik Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
