rwblinn Geschrieben May 8, 2020 at 16:56 Geschrieben May 8, 2020 at 16:56 Environment: Raspberry Pi (Raspian Buster), Python 2.7.16, MQTT Bindings 2.0.9 Issue: Publishing sample text is not displayed: mosquitto_pub -t tinkerforge/request/lcd_20x4_bricklet/rTS/write_line -m '{"line": 0, "position": 0, "text":"TEST"}' Ran Tinkerforge_mqtt with debug flag - shows an error 2020-05-08 18:42:57,560 <DEBUG> MQTT bindings: Calling function write_line for device rTS of type lcd_20x4_bricklet. 2020-05-08 18:42:57,562 <ERROR> MQTT bindings: argument for 's' must be a string (call of write_line of lcd_20x4_bricklet rTS) 2020-05-08 18:42:57,563 <DEBUG> MQTT bindings: Calling function write_line for device rTS of type lcd_20x4_bricklet succedded. 2020-05-08 18:42:57,564 <DEBUG> MQTT bindings: Publishing response to tinkerforge/response/lcd_20x4_bricklet/rTS/write_line 2020-05-08 18:42:57,569 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m8), 'tinkerforge/response/lcd_20x4_bricklet/rTS/write_line', ... (2 bytes) 2020-05-08 18:42:57,572 <DEBUG> MQTT bindings: Tested the same with a) brick viewer: text is displayed, b) Python bindings = text is displayed. Also tried other lcd20x4 mqtt functions: backlight_on & off = OK get_identity = error 2020-05-08 18:55:50,901 <DEBUG> MQTT bindings: Calling function get_identity for device rTS of type lcd_20x4_bricklet. 2020-05-08 18:55:50,909 <DEBUG> MQTT bindings: Calling function get_identity for device rTS of type lcd_20x4_bricklet succedded. Traceback (most recent call last): File "/usr/local/bin/tinkerforge_mqtt", line 7366, in on_message response = self.dispatch_call(request_type, device, uid, function, payload, response_path) File "/usr/local/bin/tinkerforge_mqtt", line 7717, in dispatch_call return self.device_call(device, device_class_name, uid, fnName, fnInfo, json_args) File "/usr/local/bin/tinkerforge_mqtt", line 7823, in device_call d["_display_name"] = display_names[dev_id] NameError: global name 'display_names' is not defined Zitieren
rtrbt Geschrieben May 11, 2020 at 08:38 Geschrieben May 11, 2020 at 08:38 Hi, I can not reproduce your first problem. The output looks like you are passing something that is not a string, but the type check of the bindings should detect that and print a more helpful error message. Does this happen every time you attempt to call write_line, or only in specific cases? Did you call any other functions before calling write_line? Your second problem should be fixed with the attached version of the bindings. Erik Edit: The first problem happens only when using Python 2. It should be fixed in the attached version. tinkerforge_mqtt_bindings_2_0_9_ee8d2719.zip Zitieren
rwblinn Geschrieben May 11, 2020 at 09:10 Autor Geschrieben May 11, 2020 at 09:10 Thanks for the update. 1/ Confirmed get_identity working. tinkerforge/request/lcd_20x4_bricklet/rTS/get_identity (null) tinkerforge/response/lcd_20x4_bricklet/rTS/get_identity {"connected_uid": "5VGrDJ", "uid": "rTS", "device_identifier": "lcd_20x4_bricklet", "hardware_version": [1, 2, 0], "position": "b", "firmware_version": [2, 0, 6], "_display_name": "LCD 20x4 Bricklet"} 2/ Write_line not working. Does this happen every time you attempt to call write_line? YES, tried on two different RPi's running latest bindings or only in specific cases? NO Did you call any other functions before calling write_line? Using bash script (tested on the two systems): cat lcd2004_write_line.sh #!/bin/bash mosquitto_pub -t tinkerforge/request/lcd_20x4_bricklet/rTS/backlight_on -m '' mosquitto_pub -t tinkerforge/request/lcd_20x4_bricklet/rTS/clear_display -m '' mosquitto_pub -t tinkerforge/request/lcd_20x4_bricklet/rTS/write_line -m '{"line": 0, "position": 0, "text":"Hello World"}' Zitieren
rtrbt Geschrieben May 11, 2020 at 10:14 Geschrieben May 11, 2020 at 10:14 Hi, Seems like my edit interleaved with you loading the thread. Can you please try again with the ee8d2719-Version? Zitieren
rwblinn Geschrieben May 11, 2020 at 10:32 Autor Geschrieben May 11, 2020 at 10:32 Tested = same error - running Python 2.7.16 (default, Oct 10 2019, 22:02:15) [GCC 8.3.0] on linux2 on a Raspberry Pi 3B+ (Buster) 2020-05-11 12:30:39,165 <DEBUG> MQTT bindings: Calling function write_line for device rTS of type lcd_20x4_bricklet. 2020-05-11 12:30:39,167 <ERROR> MQTT bindings: argument for 's' must be a string (call of write_line of lcd_20x4_bricklet rTS) 2020-05-11 12:30:39,169 <DEBUG> MQTT bindings: Calling function write_line for device rTS of type lcd_20x4_bricklet succedded. 2020-05-11 12:30:39,170 <DEBUG> MQTT bindings: Publishing response to tinkerforge/response/lcd_20x4_bricklet/rTS/write_line 2020-05-11 12:30:39,172 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m5), 'tinkerforge/response/lcd_20x4_bricklet/rTS/write_line', ... (2 bytes) Zitieren
rtrbt Geschrieben May 11, 2020 at 11:51 Geschrieben May 11, 2020 at 11:51 Are you sure that you run the right version of the bindings? I've just tested the attached zip and your script on a Pi 3B+ and it works fine. Zitieren
rwblinn Geschrieben May 11, 2020 at 12:53 Autor Geschrieben May 11, 2020 at 12:53 Confirmed working ok. Tested various RPi. Thanks a lot for your help. Appreciated. Zitieren
photron Geschrieben May 11, 2020 at 13:33 Geschrieben May 11, 2020 at 13:33 Fixes have been released as part of MQTT bindings version 2.0.10. 1 Zitieren
