Atak Geschrieben June 26, 2012 at 04:31 Geschrieben June 26, 2012 at 04:31 I'm learning Python so I wrote some scripts for the Ambient Light and Linear Poti bricklets. This may be useful for people who are new to programming. This gives a basic idea on how to use the bricklets as a switch. Ambient Light: #!/usr/bin/env python # -*- coding: utf-8 -*- import os HOST = "localhost" PORT = 4223 UID = "xxx" # Change to your UID from tinkerforge.ip_connection import IPConnection from tinkerforge.bricklet_ambient_light import AmbientLight # Callback function for illuminance callback (parameter has unit Lux/10) def cb_illuminance(illuminance): less = '''Light.\n oooooooooooooooooooooooooo\n oooooooooooooooooooooooooo\n oooooooooooooooooooooooooo\n oooooooooooooooooooooooooo\n oooooooooooooooooooooooooo\n oooooooooooooooooooooooooo''' more = '''Dark.\n --------------------------\n --------------------------\n --------------------------\n --------------------------\n --------------------------\n --------------------------''' running = True while running: # Test with print('Illuminance: ' + str(illuminance/10.0) + ' Lux') lux = str(illuminance/10.0) if str(49) < lux: os.system('clear') print less break if str(51) > lux: os.system('clear') print more break if __name__ == "__main__": ipcon = IPConnection(HOST, PORT) # Create IP connection to brickd al = AmbientLight(UID) # Create device object ipcon.add_device(al) # Add device to IP connection # Don't use device before it is added to a connection # Set Period for illuminance callback to 1s (1000ms) # Note: The illuminance callback is only called every second if the # illuminance has changed since the last call! al.set_illuminance_callback_period(1000) # Register illuminance callback to function cb_illuminance al.register_callback(al.CALLBACK_ILLUMINANCE, cb_illuminance) raw_input('Press key to exit\n') # Use input() in Python 3 ipcon.destroy() Linear Poti: #!/usr/bin/env python # -*- coding: utf-8 -*- import os HOST = "localhost" PORT = 4223 UID = "xxx" # Change to your UID from tinkerforge.ip_connection import IPConnection from tinkerforge.bricklet_linear_poti import LinearPoti # Callback function for position callback (parameter has range 0-100) def cb_position(position): less = '''Switch Off.\n -------------\n -------------\n -------------\n 0000000000000''' more = '''Switch On.\n 0000000000000\n -------------\n -------------\n -------------''' running = True while running: # Test with print('Position: ' + str(position)) slide = str(position) if str(49) < slide: os.system('clear') print less break if str(51) > slide: os.system('clear') print more break if __name__ == "__main__": ipcon = IPConnection(HOST, PORT) # Create IP connection to brickd poti = LinearPoti(UID) # Create device object ipcon.add_device(poti) # Add device to IP connection # Don't use device before it is added to a connection # Set Period for position callback to 0.05s (50ms) # Note: The position position is only called every 50ms if the # position has changed since the last call! poti.set_position_callback_period(50) # Register position callback to function cb_position poti.register_callback(poti.CALLBACK_POSITION, cb_position) raw_input('Press key to exit\n') # Use input() in Python 3 ipcon.destroy() Zitieren
Paul Geschrieben June 26, 2012 at 08:27 Geschrieben June 26, 2012 at 08:27 Cool Maybe you can put your code in the wiki into the code kitchen category too, so other people can find it there too http://www.tinkerunity.org/wiki/index.php/Category:Code-Sammlung / http://www.tinkerunity.org/wiki/index.php/Category:Python Zitieren
Atak Geschrieben June 27, 2012 at 01:19 Autor Geschrieben June 27, 2012 at 01:19 Done. Although I'm new to the Wiki stuff so I'm sure someone can make it look better. I'll add onto it as I play with Python more. Zitieren
Paul Geschrieben June 27, 2012 at 08:18 Geschrieben June 27, 2012 at 08:18 I moved your code to its own page and added it to both categories (code kitchen and python) http://www.tinkerunity.org/wiki/index.php/Ambient_Light_Switch Its easier to get an overview, if there are more code examples. You can see all Python code examples on the python page automatically http://www.tinkerunity.org/wiki/index.php/Category:Python If you have some more code snippets, just create a new page in the wiki and add the following to the bottom of the wiki page: [[Category:Code-Sammlung]] [[Category:Python]] and your new page will appear on both category pages. Zitieren
