borg Geschrieben August 25, 2014 at 19:13 Geschrieben August 25, 2014 at 19:13 MakerBeam bei Tinkerforge Blog entry
borg Geschrieben August 28, 2014 at 12:55 Geschrieben August 28, 2014 at 12:55 RED Brick in EMC laboratory Blog entry
borg Geschrieben September 9, 2014 at 17:25 Geschrieben September 9, 2014 at 17:25 New cheaper LED strips Blog entry
borg Geschrieben November 13, 2014 at 09:46 Geschrieben November 13, 2014 at 09:46 The RED Brick countdown has started Blog entry
photron Geschrieben November 13, 2014 at 18:55 Autor Geschrieben November 13, 2014 at 18:55 Plugin: Color Bricklet 2.0.1 Always use up-to-date RGB values in color temperature and illuminance calculation, independent of the color callback state Download: Color Bricklet
borg Geschrieben November 26, 2014 at 17:49 Geschrieben November 26, 2014 at 17:49 Firmwares: DC Brick 2.3.0, IMU Brick 2.3.0, Master Brick 2.3.0, Servo Brick 2.3.0, Stepper Brick 2.3.0 New SPI protocol for all Bricks (RED Brick-compatible).Increase all versions to 2.3.0 to simplify stack-compatability. All versions >= 2.3.0 are compatible to each other.Master Brick: Add support for hardware version 2.1. Download: DC Brick, IMU Brick, Master Brick, Servo Brick, Stepper Brick
batti Geschrieben December 2, 2014 at 12:39 Geschrieben December 2, 2014 at 12:39 IoT with Cumulocity and Tinkerforge Blog entry
photron Geschrieben December 9, 2014 at 16:34 Autor Geschrieben December 9, 2014 at 16:34 Brick Viewer 2.2.0 Add support for RED BrickAllow to rearrange Brick and Bricklet tabs and detach them from the main windowImprove UI for NFC/RFID Bricklet read and write operationsWindows installer and drivers are signed nowFix occasional bounce of the connect buttonFix UI font selection on Mac OS X 10.9 and 10.10 Downloads: Windows, Linux, Mac OS X
photron Geschrieben December 10, 2014 at 17:40 Autor Geschrieben December 10, 2014 at 17:40 Brick Daemon 2.2.0 Add support for RED BrickColorized log messagesDetect and drop pending requests that will never get a responseWindows installer and drivers are signed nowMac OS X installer signed on Mac OS X 10.10 to make it pass the Gatekeeper againEnable logrotate for brickd.log on LinuxRemove all categories from logging systemHandle partial writes if outgoing socket buffer is almost full Downloads: Windows, Linux (amd64, i386, armhf), Mac OS X
photron Geschrieben December 10, 2014 at 18:50 Autor Geschrieben December 10, 2014 at 18:50 Bindings: C/C++ 2.1.5, C# 2.1.3, Delphi/Lazarus 2.1.3, Java 2.1.3, JavaScript 2.0.3, LabVIEW 2.1.3, Mathematica 2.1.3, MATLAB/Octave 2.0.3, Perl 2.1.3, PHP 2.1.3, Python 2.1.3, Ruby 2.1.3, Shell 2.1.3, VB.NET 2.1.3 Add support for RED Brick [all]Make listener dispatch methods protected to allow external changes [Java]Add support for Delphi XE on Mac OS X [Delphi]Add workaround for older Delphi versions that lack TThread.CurrentThread [Delphi]Add simple library fpcmake file [Delphi]Handle EINTR error in receive loop [Python] Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, VB.NET
photron Geschrieben December 10, 2014 at 19:57 Autor Geschrieben December 10, 2014 at 19:57 Bindings: C/C++ 2.1.6, C# 2.1.4, Delphi/Lazarus 2.1.4, Java 2.1.4, JavaScript 2.0.4, LabVIEW 2.1.4, Mathematica 2.1.4, MATLAB/Octave 2.0.4, Perl 2.1.4, PHP 2.1.4, Python 2.1.4, Ruby 2.1.4, Shell 2.1.4, VB.NET 2.1.4 Add support for RED Brick [all] Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, VB.NET
borg Geschrieben December 12, 2014 at 15:50 Geschrieben December 12, 2014 at 15:50 RED Brick released Blog entry
borg Geschrieben December 17, 2014 at 12:34 Geschrieben December 17, 2014 at 12:34 Status update: Shipping at Tinkerforge Blog entry
photron Geschrieben December 18, 2014 at 18:41 Autor Geschrieben December 18, 2014 at 18:41 Brick Viewer 2.2.1 Exclude file system cache from memory value on RED Brick overview tabShow full list of available wireless networks instead of using a drop-down box on RED Brick network tabUse timeout counter to show RED Brick timeout errorsFix file progress display on RED Brick program upload dialogAdd Java main class discovery for already created RED Brick Java programs and make it abortableImprove Java class path handling for RED Brick Java programsAdd missing Java part of RED Brick program upload summaryAdd RED Brick file system settings tab to do file system expansion Downloads: Windows, Linux, Mac OS X
photron Geschrieben December 22, 2014 at 13:58 Autor Geschrieben December 22, 2014 at 13:58 Bindings: C# 2.1.5 Compiled for CLR 2.0 again, instead of CLR 4.0 (accidentally changed in 2.1.3) Download: C#
borg Geschrieben December 22, 2014 at 15:12 Geschrieben December 22, 2014 at 15:12 Plugin: NFC/RFID Bricklet 2.0.1 Asynchronously wait until pn532 is ready (fixes RED Brick incompatibility): https://github.com/Tinkerforge/nfc-rfid-bricklet/commit/10b6746f6d80776dc8d334fcaefd00c50b23d4c6 Download: NFC/RFID Bricklet
photron Geschrieben December 23, 2014 at 12:15 Autor Geschrieben December 23, 2014 at 12:15 RED Brick Images: Full and Fast 1.1 Update C# bindings to version 2.1.5Update Brick Viewer to version 2.2.1Fix pin mapping for second Master ExtensionAdd missing Delphi, Octave, Shell and Node.js version information for Brick Viewer Download: Full, Fast
borg Geschrieben December 24, 2014 at 16:03 Geschrieben December 24, 2014 at 16:03 New Master Bricks and Merry Christmas Blog entry
borg Geschrieben December 29, 2014 at 13:45 Geschrieben December 29, 2014 at 13:45 Bindings: Delphi/Lazarus 2.1.5 Add support for arrays in callbacks (used by RED Brick) Download: Delphi/Lazarus
borg Geschrieben December 30, 2014 at 09:02 Geschrieben December 30, 2014 at 09:02 RED Brick Images: Full and Fast 1.2 Update Delphi/Lazarus Bindings to version 2.1.5Fix intermittent missing Loopback-Interface problemFix mixing setuid flag in /usr/bin/sudoAdd gphoto2 and libgphoto2 Download: Full, Fast
borg Geschrieben December 30, 2014 at 13:32 Geschrieben December 30, 2014 at 13:32 Plugin: Temperature IR 2.0.4 Make sure that select line is pulled, so that I2C switch on Master Brick 2.1 works properly Download: Temperature IR Bricklet
borg Geschrieben December 31, 2014 at 15:13 Geschrieben December 31, 2014 at 15:13 RED Brick Images: Full and Fast 1.3 Fix problems wit name resolution (DNS) Download: Full, Fast
batti Geschrieben January 1, 2015 at 22:15 Geschrieben January 1, 2015 at 22:15 Happy New Year from Tinkerforge Blog entry
borg Geschrieben January 6, 2015 at 15:43 Geschrieben January 6, 2015 at 15:43 Plugin: Temperature 2.0.3 Return -99.99°C in case of an error during communication (before it would block the whole stack) Download: Temperature Bricklet
photron Geschrieben February 3, 2015 at 10:50 Autor Geschrieben February 3, 2015 at 10:50 Brick Daemon 2.2.1 Improve RED Brick hotplug detection and error handling on WindowsAdd debug filter to fine-tune debug outputWait for WebSocket handshake completion before sending dataUse redapid version as RED Brick firmware versionDon't send packet twice after partial write Downloads: Windows, Linux (amd64, i386, armhf), Mac OS X
