photron Geschrieben April 9, 2014 at 17:49 Autor Geschrieben April 9, 2014 at 17:49 Brick Daemon 2.1.0 Add authentication support (disabled by default)Add WebSocket support (port 4280, disabled by default)Make USB device lookup more robust in case of some USB driver bugs on WindowsUpdate bundled libusb to 1.0.18 on Mac OS X, fixes a SIGFPE bugUpdate bundled libusb to 1.0.18 on Windows, adds support for Intel and AMD USB 3.0 root hubsImprove handling of request packets with invalid length in the headerHandle rare case of socket_receive failing with EWOULDBLOCKDon't lose connection to USB devices on host-resume-from-suspend on Linux and Mac OS X (requires pm-utils on Linux)Increase upper limits for pending requests and USB write queuesAdd socket_send queue for clients, enqueue packet instead of disconnecting client if socket_send would blockOnly dispatch response to the first client with a matching pending request, fixes response duplication Downloads: Windows, Linux (amd64, i386, armhf), Mac OS X
borg Geschrieben April 9, 2014 at 18:36 Geschrieben April 9, 2014 at 18:36 Firmware: Master Brick 2.2.1 Remove "Suspend to Disk fix", seems to make problems on some windows versions Download: Master Brick
borg Geschrieben April 11, 2014 at 15:56 Geschrieben April 11, 2014 at 15:56 RED Brick circuit boards arrived Blog entry
batti Geschrieben April 17, 2014 at 14:56 Geschrieben April 17, 2014 at 14:56 10% Easter Discount Blog entry
batti Geschrieben April 17, 2014 at 20:45 Geschrieben April 17, 2014 at 20:45 MATLAB and Octave Bindings released Blog entry
borg Geschrieben May 13, 2014 at 15:32 Geschrieben May 13, 2014 at 15:32 RED Brick news! Prototype works! Blog entry
borg Geschrieben May 23, 2014 at 12:47 Geschrieben May 23, 2014 at 12:47 RED Brick: Does it work? Blog entry
batti Geschrieben June 6, 2014 at 16:29 Geschrieben June 6, 2014 at 16:29 Revised Documentation and Kits Blog entry
batti Geschrieben June 12, 2014 at 18:00 Geschrieben June 12, 2014 at 18:00 Maker Faire 2014 Blog entry
borg Geschrieben June 20, 2014 at 14:52 Geschrieben June 20, 2014 at 14:52 RED Brick Software Infrastructure Blog entry
photron Geschrieben June 24, 2014 at 13:47 Autor Geschrieben June 24, 2014 at 13:47 Bindings: C/C++ 2.1.1 Add extern "C" markup to all files to force proper symbol names in C++Explicitly use ANSI version of WinAPI functions to support UNICODE builds on WindowsAdd simple library Makefile for LinuxFix race condition between device destruction and callback dispatch Download: C/C++
photron Geschrieben July 3, 2014 at 15:52 Autor Geschrieben July 3, 2014 at 15:52 Bindings: C/C++ 2.1.2, C# 2.1.1, Delphi/Lazarus 2.1.1, Java 2.1.1, JavaScript 2.0.1, LabVIEW 2.1.1, Mathematica 2.1.1, MATLAB/Octave 2.0.1, Perl 2.1.1, PHP 2.1.1, Python 2.1.1, Ruby 2.1.1, Shell 2.1.1, VB.NET 2.1.1 Add support for WS2811 and WS2812 to LED Strip Bricklet API [all] Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, VB.NET
photron Geschrieben July 3, 2014 at 15:52 Autor Geschrieben July 3, 2014 at 15:52 Brick Viewer 2.1.1 Use a more recent UI style on WindowsStore port, authentiation options and secret per host and double host history lengthUse a signed Brick bootloader driver on WindowsAdd support for WS2811 and WS2812 to LED Strip Bricklet plugin Downloads: Windows, Linux, Mac OS X
borg Geschrieben July 3, 2014 at 16:26 Geschrieben July 3, 2014 at 16:26 Plugin: LED Strip Bricklet 2.0.2 Add support for WS2811 and WS2812 Download: LED Strip Bricklet
photron Geschrieben July 8, 2014 at 08:38 Autor Geschrieben July 8, 2014 at 08:38 Bindings: C/C++ 2.1.3 Fix strnlen redeclaration in some MinGW environments Download: C/C++
borg Geschrieben July 10, 2014 at 11:54 Geschrieben July 10, 2014 at 11:54 Plugin: LED Strip Bricklet 2.0.4 Use measured timings instead of faulty datasheet values Download: LED Strip Bricklet Firmwares: DC Brick 2.0.3, IMU Brick 2.0.4, Master Brick 2.2.2, Servo Brick 2.0.5, Stepper Brick 2.0.5 Remove rarely used USB hotplug feature (prevents accidiential stack restart after heatup) Download: DC Brick, IMU Brick, Master Brick, Servo Brick, Stepper Brick
borg Geschrieben July 10, 2014 at 12:37 Geschrieben July 10, 2014 at 12:37 LED Strip Bricklet supports WS2811 and WS2812(B) Blog entry
borg Geschrieben July 22, 2014 at 11:56 Geschrieben July 22, 2014 at 11:56 Plugin: LED Strip Bricklet 2.0.5 Frame duration of 0 now means that no more frames shall be setSet RGB values at least two times to make sure that they are really writtenFix possible overflow if Brick with two Bricklet connectors is used Download: LED Strip Bricklet
borg Geschrieben July 25, 2014 at 12:57 Geschrieben July 25, 2014 at 12:57 API Bindings and package management Blog entry
photron Geschrieben July 31, 2014 at 14:16 Autor Geschrieben July 31, 2014 at 14:16 Brick Daemon 2.1.1 Add live debug log view to logviewer.exe on WindowsInclude signed version of the Brick bootloader driver for WindowsWorkaround race condition in USB hotplug handling on LinuxFix crash if client with pending responses disconnectsFix possible mismatch while handling responses for identical requestsAvoid broadcasting unexpected responses in most cases Downloads: Windows, Linux (amd64, i386, armhf), Mac OS X
borg Geschrieben August 4, 2014 at 15:30 Geschrieben August 4, 2014 at 15:30 Fully automatic photography turntable Blog entry
borg Geschrieben August 11, 2014 at 17:18 Geschrieben August 11, 2014 at 17:18 New Bricklets: Color, NFC/RFID and Solid State Relay Blog entry
photron Geschrieben August 11, 2014 at 17:58 Autor Geschrieben August 11, 2014 at 17:58 Bindings: C/C++ 2.1.4, C# 2.1.2, Delphi/Lazarus 2.1.2, Java 2.1.2, JavaScript 2.0.2, LabVIEW 2.1.2, Mathematica 2.1.2, MATLAB/Octave 2.0.2, Perl 2.1.2, PHP 2.1.2, Python 2.1.2, Ruby 2.1.2, Shell 2.1.2, Visual Basic .NET 2.1.2 Add support for Color, NFC/RFID and Solid State Relay Bricklet [all]Rename bindings/ folder to source/ in ZIP file [C/C++, Delphi]Replace System.console() usage with an Eclipse compatible pattern in examples [Java]Move NPM package into nodejs/ folder of ZIP file [JavaScript]Add main Tinkerforge.js script to simplify direct usage of the Node.js source code [JavaScript]Only use MSG_NOSIGNAL if it's really defined [Perl]Remove CPAN package from ZIP file, include relevant files into the source/ folder [Perl]Get rid of the egg and easy_install, use setuptools directly or pip instead [Python] Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, Visual Basic .NET
photron Geschrieben August 11, 2014 at 17:58 Autor Geschrieben August 11, 2014 at 17:58 Brick Viewer 2.1.2 Add support for Color, NFC/RFID and Solid State Relay BrickletRename main.exe to brickv.exe on WindowsMake rainbow work better on small LED counts and add moving-dot mode to LED Strip Bricklet pluginAllow double click anywhere in a device tree row to jump to the corresponding tab Downloads: Windows, Linux, Mac OS X
photron Geschrieben August 19, 2014 at 10:23 Autor Geschrieben August 19, 2014 at 10:23 Plugin: Piezo Speaker Bricklet 2.0.2 Duration 0 stops beep, duration 4294967295 (UINT32_MAX) results in an infinite beep Download: Piezo Speaker Bricklet
