borg Geschrieben December 13, 2013 at 15:07 Geschrieben December 13, 2013 at 15:07 Last minute Christmas discount, new accessories, new kit Blog entry
borg Geschrieben December 16, 2013 at 18:43 Geschrieben December 16, 2013 at 18:43 New Dual Relay Bricklet Blog entry
photron Geschrieben December 19, 2013 at 16:20 Autor Geschrieben December 19, 2013 at 16:20 Plugins: Remote Switch Bricklet 2.0.1 Support addressing types of Intertechno and ELRO Home Easy devices Download: Remote Switch Bricklet
photron Geschrieben December 19, 2013 at 17:37 Autor Geschrieben December 19, 2013 at 17:37 Bindings: C/C++ 2.0.13, C# 2.0.13, Delphi 2.0.15, Java 2.0.14, PHP 2.0.12, Python 2.0.13, Ruby 2.0.13, Shell 2.0.5, VB.NET 2.0.9 Add Get/SetClockFrequency function to LED Strip Bricklet API [all]Fix mixup of Set/GetDateTimeCallbackPeriod and Set/GetMotionCallbackPeriod in GPS Bricklet API [all]Support addressing types of Intertechno and ELRO Home Easy devices in Remote Switch Bricklet API [all] Download: C/C++, C#, Delphi, Java, PHP, Python, Ruby, Shell, VB.NET
photron Geschrieben December 19, 2013 at 17:54 Autor Geschrieben December 19, 2013 at 17:54 Plugins: LED Strip Bricklet 2.0.1 Add Get/SetClockFrequency function Download: LED Strip Bricklet
borg Geschrieben December 19, 2013 at 18:02 Geschrieben December 19, 2013 at 18:02 Plugins: Ambient Light Bricklet 2.0.3, Analog In Bricklet 2.0.4, Barometer Bricklet 2.0.2, Distance IR Bricklet 2.0.2, Distance US Bricklet 2.0.1, Humidity Bricklet 2.0.2, Industrial Dual 0-20mA Bricklet 2.0.1, Joystick Bricklet 2.0.3, Linear Poti Bricklet 2.0.2, Line Bricklet 2.0.1, Moisture Bricklet 2.0.1, PTC Bricklet 2.0.1, Rotary Encoder Bricklet 2.0.1, Rotary Poti Bricklet 2.0.2, Sound Intensity Bricklet 2.0.1, Temperature Bricklet 2.0.2, Temperature IR Bricklet 2.0.2, Voltage/Current Bricklet 2.0.4 Fix wrong length for GetDebounce packet (through brickletlib). Download Plugin: Ambient Light Bricklet 2.0.3, Analog In Bricklet 2.0.4, Barometer Bricklet 2.0.2, Distance IR Bricklet 2.0.2, Distance US Bricklet 2.0.1, Humidity Bricklet 2.0.2, Industrial Dual 0-20mA Bricklet 2.0.1, Joystick Bricklet 2.0.3, Linear Poti Bricklet 2.0.2, Line Bricklet 2.0.1, Moisture Bricklet 2.0.1, PTC Bricklet 2.0.1, Rotary Encoder Bricklet 2.0.1, Rotary Poti Bricklet 2.0.2, Sound Intensity Bricklet 2.0.1, Temperature Bricklet 2.0.2, Temperature IR Bricklet 2.0.2, Voltage/Current Bricklet 2.0.4
photron Geschrieben December 19, 2013 at 19:18 Autor Geschrieben December 19, 2013 at 19:18 Brick Viewer 2.0.9 Support Get/SetClockFrequency in LED Strip Bricklet pluginShow "motion detected" in red in Motion Detector Bricklet pluginSupport Intertechno and ELRO Home Easy addressing types in Remote Switch Bricklet plugin Downloads: Windows, Linux, Mac OS X
borg Geschrieben January 6, 2014 at 10:08 Geschrieben January 6, 2014 at 10:08 Plugins: Distance US Bricklet 2.0.2 Reorder elements in BrickContext to satisfy 256 byte size limit Download: Distance US Bricklet
photron Geschrieben January 14, 2014 at 16:15 Autor Geschrieben January 14, 2014 at 16:15 Perl bindings ready Blog entry
borg Geschrieben January 20, 2014 at 16:46 Geschrieben January 20, 2014 at 16:46 Plugins: Dual Button Bricklet 2.0.1 Fix selected_led_state bug Download: Dual Button Bricklet
borg Geschrieben January 20, 2014 at 16:58 Geschrieben January 20, 2014 at 16:58 IoT with JavaFX / iOS Apps in App Store Blog entry
borg Geschrieben January 21, 2014 at 12:58 Geschrieben January 21, 2014 at 12:58 Plugins: Dual Button Bricklet 2.0.2 Fix left/right button permutation Download: Dual Button Bricklet
borg Geschrieben January 22, 2014 at 12:53 Geschrieben January 22, 2014 at 12:53 "Starter Kit: Server Room Monitoring" now with powder coated aluminum front panel: Blog entry
borg Geschrieben February 7, 2014 at 19:25 Geschrieben February 7, 2014 at 19:25 Mathematica Bindings now available Blog entry
batti Geschrieben February 10, 2014 at 22:04 Geschrieben February 10, 2014 at 22:04 Starter Kit: Blinkenlights now available Blog entry
photron Geschrieben February 14, 2014 at 13:53 Autor Geschrieben February 14, 2014 at 13:53 Bindings: Perl 2.0.1 Put all packages into Tinkerforge namespaceFix signature of get/set_response_expected(_all) functions to match the documentationHandle error code in response packagesAdd Error class to report an error code in addition to the error message Download: Perl
photron Geschrieben February 20, 2014 at 10:21 Autor Geschrieben February 20, 2014 at 10:21 Plugins: IO-16 Bricklet 2.0.5 Fix direction_mask return of get_port_configurationUse correct internal register in set_selected_values Download: IO-16 Bricklet
borg Geschrieben February 21, 2014 at 18:16 Geschrieben February 21, 2014 at 18:16 Tinkerforge goes Stand-Alone aka RED Brick Blog entry
photron Geschrieben February 24, 2014 at 12:37 Autor Geschrieben February 24, 2014 at 12:37 Bindings: PHP 2.0.13 Fix passing $userData parameter to callbacks Download: PHP
borg Geschrieben February 25, 2014 at 21:10 Geschrieben February 25, 2014 at 21:10 Swiss Reseller Blog entry
borg Geschrieben March 6, 2014 at 17:09 Geschrieben March 6, 2014 at 17:09 LabVIEW Bindings available Blog entry
photron Geschrieben March 25, 2014 at 12:42 Autor Geschrieben March 25, 2014 at 12:42 Bindings: Perl 2.0.2 Use better markup in inline documentationRework socket sharing between threads to fix (auto-re)connection handling Download: Perl
borg Geschrieben April 9, 2014 at 08:19 Geschrieben April 9, 2014 at 08:19 Firmware: Master Brick 2.2.0 Add support for Websockets for Ethernet ExtensionAdd support for authentication of Ethernet/WIFI ExtensionReset on USB Resume, to get a clean stateIncrease USB hotplug detect thresholdSPI stack slave gives up immediately if message length too long Download: Master Brick
photron Geschrieben April 9, 2014 at 17:46 Autor Geschrieben April 9, 2014 at 17:46 Bindings: C/C++ 2.1.0, C# 2.1.0, Delphi 2.1.0, Java 2.1.0, JavaScript 2.0.0, LabVIEW 2.1.0, Mathematica 2.1.0, Perl 2.1.0, PHP 2.1.0, Python 2.1.0, Ruby 2.1.0, Shell 2.1.0, VB.NET 2.1.0 Add authentication support to IPConnection and Master Brick API [all]Initial JavaScript bindings release [JavaScript]Rewrite endian handling logic to work without detecting the actual host endian [C/C++]Exit receive thread on socket shutdown by peer to avoid triggering multiple disconnected callbacks [C#]Add TDeviceBase class as empty base class for all devices [Delphi]Add TinkerforgeListener and DeviceListener as base interfaces for all listeners [Java]Escape special HTML characters in JavaDoc [Java]Make IPConnection locks proper members of the class instance [Perl]Make Brick and Bricklet classes proper subclasses of Device [Perl]Don't overwrite auto_reconnect option in set_timeout function [Perl]Properly handle socket shutdown in receive thread [Ruby] Download: C/C++, C#, Delphi, Java, JavaScript, LabVIEW, Mathematica, Perl, PHP, Python, Ruby, Shell, VB.NET
photron Geschrieben April 9, 2014 at 17:47 Autor Geschrieben April 9, 2014 at 17:47 Brick Viewer 2.1.0 Add authentication supportAdd authentication configuration for Ethernet and WIFI Extension to Master Brick pluginAdd WebSocket configuration for Ethernet Extension to Master Brick pluginFix temperature averaging bug in Barometer Bricklet pluginFix Dual Button Bricklet left/right permutationReduce long-term memory usage by properly removing widgets on device disconnect Downloads: Windows, Linux, Mac OS X
