photron Geschrieben June 6, 2019 at 11:13 Autor Share Geschrieben June 6, 2019 at 11:13 Firmware: Outdoor Weather Bricklet 2.0.4 Increase minimum gap between station/sensor messages to filter duplicates Download: Outdoor Weather Bricklet Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben June 11, 2019 at 16:14 Autor Share Geschrieben June 11, 2019 at 16:14 Bindings: MQTT 2.0.6, Rust 2.0.10 Fix JSON parsing in Python < 3.6 [MQTT]Fix streaming of fixed length parameters [Rust] Download: MQTT, Rust Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben June 12, 2019 at 13:33 Autor Share Geschrieben June 12, 2019 at 13:33 Bindings: Perl 2.1.23 Fix UID decoding on RED Brick Download: Perl Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben June 13, 2019 at 08:50 Share Geschrieben June 13, 2019 at 08:50 Firmware: GPS V2 Bricklet 2.0.6 Fix speed overflow at speeds >=214.74km/h Download: GPS Bricklet 2.0 Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben June 19, 2019 at 16:40 Autor Share Geschrieben June 19, 2019 at 16:40 Bindings: Rust 2.0.11 Allow device construction with an IpConnectionRequestSender Download: Rust Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 2, 2019 at 17:04 Autor Share Geschrieben July 2, 2019 at 17:04 Brick Daemon 2.4.0 Add support for HAT (Zero) Brick (SPI connected Bricklets)Install Log Viewer start menu link for all users on WindowsAdd commandline options to override config, log and PID file location on Linux and macOSRemove accidental dependency to libusb 1.0.20 on LinuxReplace Event Log usage with persistent log file on WindowsExtend Log Viewer to start/stop brickd, view log file and edit config file on WindowsFix rare crash in WIFI Extension 2.0 mesh packet handlingAdd support for receiving multiple response packets per USB read transferUpdate bundled libusb to 1.0.23-rc1 on Windows and macOS, this fixes problems with ROOT/SYSTEM/0001 USB hubs on WindowsBind to all IP addresses resolved from the listen.address config option, instead of just the first one Downloads: Windows, Linux (amd64, i386, armhf), macOS Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 11, 2019 at 13:18 Autor Share Geschrieben July 11, 2019 at 13:18 Brick Viewer 2.4.5 Improve GUI and error handling of RS485 Bricklet pluginImprove WIFI Extension 2.0 configuration validationHandle spectrum stream-out-of-sync error for Sound Pressure Level BrickletHandle station/sensor loss for Outdoor Weather BrickletDon't trigger overview updates while RED Brick plugin is not visibleFix duplicated async-reads in RED Brick plugin script managerEnable Retina mode on macOSFix upload of empty files to RED BrickFix timezone setting for RED BrickMake WIFI Extension 2.0 flashing more robust by increasing the number of bootloader connection attempts Downloads: Windows, Linux, macOS Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 16, 2019 at 16:06 Autor Share Geschrieben July 16, 2019 at 16:06 Brick Viewer 2.4.6 Fix message box explosion for color gradient with one LED in LED Strip Bricklet 2.0 pluginOnly check WIFI Extension 2.0 AP password length if password is changed Downloads: Windows, Linux, macOS Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben August 1, 2019 at 11:43 Share Geschrieben August 1, 2019 at 11:43 Firmware: Industrial Dual Analog In V2 Bricklet 2.0.2 Fix error in sample rate configurationUse coop task instead of complicated state machineProperly reconfigure ADC in case of invalid data Download: Industrial Dual Analog In 2.0 Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 12, 2019 at 17:23 Autor Share Geschrieben August 12, 2019 at 17:23 RED Brick Image 1.14 Add Python 3 dependencies for Brick Viewer version >= 2.4.0Update Brick Daemon to version 2.4.0Update Brick Viewer to version 2.4.6Add PIL for Python 2 and 3Update all API bindings: C/C++ 2.1.25, C# 2.1.23, Delphi/Lazarus 2.1.24, Java 2.1.23, JavaScript 2.1.23, Octave 2.0.23, Perl 2.1.22, PHP 2.1.22, Python 2.1.22, Ruby 2.1.22, Shell 2.1.22, Visual Basic .NET 2.1.22 Download: RED Brick Image Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben August 13, 2019 at 12:43 Share Geschrieben August 13, 2019 at 12:43 Firmware: Thermal Imaging Bricklet 2.0.4 Double buffer lepton statistics to prevent statistics tearing Download: Thermal Imaging Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben August 19, 2019 at 09:28 Share Geschrieben August 19, 2019 at 09:28 Firmware: Piezo Speaker Bricklet 2.0.3 Don't disable IRQs during calibration, since newer Brick versions use interrupts during I2C communication Download: Piezo Speaker Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 19, 2019 at 15:15 Autor Share Geschrieben August 19, 2019 at 15:15 Firmware: OLED 128x64 Bricklet 2.0 2.0.5 Make the clear-display function obey the automatic-draw config Download: LCD 128x64 Bricklet 2.0 2.0.5 Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 23, 2019 at 17:04 Autor Share Geschrieben August 23, 2019 at 17:04 Bindings: C/C++ 2.1.26, C# 2.1.24, Delphi/Lazarus 2.1.25, Go 2.0.4, Java 2.1.24, JavaScript 2.1.24, LabVIEW 2.1.23, Mathematica 2.1.23, MATLAB/Octave 2.0.24, MQTT 2.0.7, Perl 2.1.24, PHP 2.1.23, Python 2.1.23, Ruby 2.1.23, Rust 2.0.12, Shell 2.1.23, Visual Basic .NET 2.1.23 Add support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0, Rotary Poti 2.0 and XMC1400 Breakout Bricklet [All]Add Get/SetFilterConfiguration functions to Accelerometer Bricklet 2.0 API [All]Add ConversionTime constants to Voltage/Current Bricklet 2.0 API [All]Fix misaligned array access in callback wrapper function [C/C++]Don't leak the get_random_uint32 symbol [C/C++]Break API to stop mixing object and function pointers for callback functions [C/C++]Allow to pass non-constant values to parameters with constants [Go]Break API to remove enumerate response structure: enumerate callback uses parameters directly, which is more in line with all other callbacks [Go]Increase minimum JDK version from 1.6 to 8 [Java]More robust connection handling [MQTT]Fix init file loading [MQTT] Download: C/C++, C#, Delphi/Lazarus, Go, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, MQTT, Perl, PHP, Python, Ruby, Rust, Shell, Visual Basic .NET Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 26, 2019 at 09:59 Autor Share Geschrieben August 26, 2019 at 09:59 Brick Viewer 2.4.7 Add support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0, Rotary Poti 2.0 and XMC1400 Breakout BrickletAdd Data Logger support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0 and Rotary Poti 2.0 BrickletFix latest firmware version discovery if no Internet connection is availableAdd interpolation and scale factor options to Thermal Imaging Bricklet pluginDownload firmware files using HTTPSUpdates/Flashing dialog can download Brick Viewer updatesFix WIFI Extension 2.0 flashing to fix web interfaceDon't try to use invalid IMU Brick calibrationDon't crash if OpenGL is not availableCorrectly handle Modbus response with unknown request in RS485 Bricklet plugin Downloads: Windows, Linux, macOS Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 26, 2019 at 13:15 Autor Share Geschrieben August 26, 2019 at 13:15 Brick Logger 2.1.1 Add support for Color 2.0, Compass, Distance US 2.0, Energy Monitor, Multi Touch 2.0 and Rotary Poti 2.0 Bricklet Downloads: Windows, Linux, macOS, RED Brick Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 27, 2019 at 10:18 Autor Share Geschrieben August 27, 2019 at 10:18 Brick Viewer 2.4.8 Fix firmware download on newer macOS versions Downloads: Windows, Linux, macOS Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben August 28, 2019 at 09:28 Share Geschrieben August 28, 2019 at 09:28 Firmware: Air Quality Bricklet 2.0.5 Update Bosch BSEC to v1.4.7.4Improve outlier value handling Download: Air Quality Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben August 28, 2019 at 10:19 Share Geschrieben August 28, 2019 at 10:19 Firmware: CO2 V2 Bricklet 2.0.2 Improve I2C error handling Download: CO2 2.0 Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben September 2, 2019 at 18:39 Autor Share Geschrieben September 2, 2019 at 18:39 Brick Viewer 2.4.9 Fix Bricklet auto-update crashAllow to choose other versions than the latest when flashing firmwaresAllow to write hex bytes in hex mode in RS485 Bricklet pluginAllow to specify coil/register values when writing multiple coils/registers in RS485 Bricklet pluginDelete key works correct in RED Brick plugin console tab Downloads: Windows, Linux, macOS Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben September 9, 2019 at 08:01 Share Geschrieben September 9, 2019 at 08:01 Firmware: Joystick V2 Bricklet 2.0.2 Fix bug in callback handler Download: Joystick 2.0 Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben September 9, 2019 at 12:10 Share Geschrieben September 9, 2019 at 12:10 Firmware: Energy Monitor Bricklet 2.0.1 Show voltage and current of 0 if the waveform has no zero-crossings Download: Energy Monitor Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben October 28, 2019 at 20:11 Share Geschrieben October 28, 2019 at 20:11 Firmware: Piezo Speaker 2.0 Bricklet 2.0.2 Fix remaining beep duration calculation Download: Piezo Speaker 2.0 Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben November 20, 2019 at 15:46 Autor Share Geschrieben November 20, 2019 at 15:46 Firmware: LED Strip Bricklet 2.0 2.0.3 Fix set-led-values length check to allow setting the last (6143th) LED as well Fix streaming logic of get-led-values for length above 60 LEDs Download: LED Strip 2.0 Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben November 21, 2019 at 14:20 Share Geschrieben November 21, 2019 at 14:20 Firmware: DMX Bricklet 2.0.3 Add 4us wait-time between slots (some slaves can not handle 0us wait time) Download: DMX Link zu diesem Kommentar Share on other sites More sharing options...
