Announcements
photron
Bindings: C/C++ 2.1.24, C# 2.1.22, Delphi/Lazarus 2.1.23, Go 2.0.2, Java 2.1.22, JavaScript 2.1.22, LabVIEW 2.1.21, Mathematica 2.1.21, MATLAB/Octave 2.0.22, Perl 2.1.21, PHP 2.1.21, Python 2.1.21, Ruby 2.1.21, Rust 2.0.8, Shell 2.1.21, Visual Basic .NET 2.1.21
  • Add support for Accelerometer 2.0 and Ambient Light 3.0 Bricklet [all]
  • Check for Python 2.6 instead of 2.5 to match Python API bindings requirements [shell]
Download: C/C++, C#, Delphi/Lazarus, Go, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Rust, Shell, Visual Basic .NET
Firmwares: DC Brick 2.3.9, IMU Brick 2.3.9, IMU 2.0 Brick 2.0.14, Master Brick 2.4.10, Servo Brick 2.3.9, Silent Stepper Brick 2.0.0, Stepper Brick 2.3.10
  • Fix Bricklet port miss-identification
  • Increase SPI stack timeout (for RED Brick)
  • Fix bugs in set/get_spitfp_* functions
Download: DC Brick, IMU Brick, IMU 2.0 Brick, Master Brick, Servo Brick, Silent Stepper Brick, Stepper Brick
Kit Demos 1.1.0: Starter Kit: Blinkenlights, Starter Kit: Camera Slider, Tabletop Weather Station, Starter Kit: Weather Station
  • Port to Python 3 and PyQt 5 [all]
  • Install start menu link for all users on Windows [all]
  • Add support for Ambient Light Bricklet 3.0 [starter Kit: Weather Station]
  • Add support for Barometer Bricklet 2.0 [starter Kit: Weather Station]
  • Use correct charset for drawing non-ASCII text on LCD 20x4 Bricklet [starter Kit: Weather Station]
Downloads:
Brick Viewer 2.4.0
  • Port to Python 3, PyQt 5 and QtOpenGL
  • Add firmware/software update notifications in setup and device tabs
  • Fix RED Brick Tinkerforge software update for Perl and Brick Viewer
  • Add RED Brick server room monitoring support for Ambient Light 3.0, Humidity 2.0, Industrial Digital In 4, Industrial Digital In 4 2.0, IO-4, IO-4 2.0 and Temperature 2.0 Bricklet
  • Improve flashing error reporting
  • Redesign device tab detach icon
  • Fix serial port auto-selection for Brick flashing on macOS
  • Add splash screen
  • Add checkbox to use Qt Fusion GUI style instead of platform GUI style
  • Fix HSL color handling in RGB LED plugin
  • Precompile Python code when installing Debian package
  • Sort Bricklets connected to Master Brick on setup tab before stacked Bricks
  • Connect when return/enter key is pressed in host, port or secret input fields
  • Fix RED Brick console tab font on macOS
  • Fix race condition between connection and WIFI Extension 2.0 version logic that could result in Brick Viewer hanging in the connecting state
  • Stop overemphasizing sensor noise in plots by limiting the minimum y-axis size relative to the sensor resolution
Downloads: Windows, Linux, macOS
Brick Viewer 2.4.2
  • Minor tweaks in RED Brick Tinkerforge Software update detection
  • Fix crash in IO-16 Bricklet 2.0 plugin
  • Add Alt-S shortcut for switching to setup tab
  • Fix hacks for progress bar text in Fusion GUI style on macOS
  • Show proper error message if trying to start/install on unsupported macOS (< 10.11) or Windows (< 7) version
  • Fix crash in RED Brick date/time settings tab
  • Fix flashing of Bricklets connected to Isolator Bricklets
  • Fix integer/float division mixups
  • Improve error reporting for Brick flashing and RED Brick serial console
  • Fix blue/green channel mixup in Color Bricklet plugin
Firmware: Dual Relay Bricklet 2.0.1, Industrial Dual Relay Bricklet 2.0.2, Solid State Relay Bricklet 2.0.1
  • Don't clear monoflop time on monoflop abort to match documentation
Download: Dual Relay, Industrial Dual Relay, Solid State Relay
Firmware: Industrial Quad Relay Bricklet 2.0 2.0.2
  • Make monoflop time-remaining count down instead of up
Download: Industrial Quad Relay 2.0
Firmware: IO-4 Bricklet 2.0 2.0.3
  • Abort active monoflop/PWM on set-configuration call for output
  • Don't clear monoflop time on monoflop done/abort to match documentation
Download: IO-4 2.0
Firmware: Solid State Relay Bricklet 2.0 2.0.2
  • Make get-monoflop always return the current state to match documentation
Download: Solid State Relay 2.0
Firmware: Industrial Digital Out 4 Bricklet 2.0 2.0.1, IO-16 Bricklet 2.0 2.0.1
  • Abort active monoflop on set-(selected-)value call
Download: Industrial Digital Out 4 2.0, IO-16 2.0
Brick Viewer 2.4.3
  • Fix date display format for triggered Real-Time Clock Bricklet (2.0) alarms
  • Always show correct Dual Button Bricklet (2.0) button state
  • Don't leave Thermal Imaging Bricklet image callback enabled on exit
  • Fix off-by-one errors in plot curves and y-axis
  • Improve RED Brick communication error handling
  • Stop preselecting serial port for Brick flashing
  • Stop Qt from adding UTF-8 BOM when copying text to the clipboard on macOS
  • Fix Ethernet Extension configuration check
  • Port IMU Brick (2.0) 3D view to modern OpenGL making it work on Raspberry Pi
Bindings: C/C++ 2.1.25, C# 2.1.23, Delphi/Lazarus 2.1.24, Go 2.0.3, Java 2.1.23, JavaScript 2.1.23, LabVIEW 2.1.22, Mathematica 2.1.22, MATLAB/Octave 2.0.23, MQTT 2.0.5, Perl 2.1.22, PHP 2.1.22, Python 2.1.22, Ruby 2.1.22, Rust 2.0.9, Shell 2.1.22, Visual Basic .NET 2.1.22
  • Add support for CO2 2.0, E-Paper 296x128, Hall Effect 2.0, Joystick 2.0, Laser Range Finder 2.0, Linear Poti 2.0, Piezo Speaker 2.0, RGB LED 2.0 and Segment Display 4x7 2.0 Bricklet and HAT and HAT Zero Brick [all]
  • Add remove-calibration and get/set-background-calibration-duration functions to Air Quality Bricklet API [all]
  • Properly check UIDs and report invalid UIDs [all]
  • Fix IP Connection auto-reconnect setting [Go]
  • Properly strip trailing NUL-bytes from UIDs in enumerate callback [Go]
  • Fix false-positive ArrayIndexOutOfBoundsExceptions in Industrial Counter Bricklet setAllCounterActive, Industrial Digital Out 4 Bricklet 2.0 setValue, Industrial Quad Relay Bricklet 2.0 setValue and IO-4 Bricklet 2.0 setValue methods [Java]
  • Fix IP Connection disconnect probe handling [JavaScript]
  • Add -v/--version parameter [MQTT]
  • Fix handling of empty input streams
Download: C/C++, C#, Delphi/Lazarus, Go, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, MQTT, Perl, PHP, Python, Ruby, Rust, Shell, Visual Basic .NET
Brick Viewer 2.4.4
  • Add Data Logger support for CO2 2.0, Hall Effect 2.0, Laser Range Finder 2.0, Linear Poti 2.0, Joystick 2.0 and Segment Display 4x7 2.0 Bricklet and HAT and HAT Zero Brick
  • Fix some string conversions in RED Brick plugin
  • Show Master Extensions on RED Brick in devices tree
  • Fix WIFI Extension firmware version lookup in Master Brick plugin
  • Show WIFI Extension firmware version in Master Brick plugin
We found a bug in version 2.0.2 of the Thermal Imaging Bicklet with the communication between Brick and Bricklet. This bug could result in an incease of unnecessary CRC errors in the communication (if you were using the Thermal-Image-Getter). After a long runtime this could result in some kind of error-loop between the Brick and Bricklet which could result in an unreachable Thermal Imaging Bricklet.
The bugfix is in the general implementation of the Tinkerforge SPI Protocol (SPITFP). Because of this there is a new firmware (with this bugfix) for all Bricklets with 7 pole connector.
Firmware: CAN Bricklet 2.0 2.0.2, Temperature IR Bricklet 2.0 2.0.4, NFC Bricklet 2.0.4, Linear Poti Bricklet 2.0 2.0.1, Segment Display 4x7 Bricklet 2.0 2.0.1, Joystick Bricklet 2.0 2.0.1, LCD 128x64 Bricklet 2.0.7, Particulate Matter Bricklet 2.0.2, DMX Bricklet 2.0.2, Outdoor Weather Bricklet 2.0.3, Thermal Imaging Bricklet 2.0.3, LED Strip Bricklet 2.0 2.0.2, OLED 128x64 Bricklet 2.0 2.0.4, RS485 Bricklet 2.0.4, Industrial Dual 0-20mA Bricklet 2.0 2.0.1, Rotary Encoder Bricklet 2.0 2.0.4, CO2 Bricklet 2.0 2.0.1, RGB LED Button Bricklet 2.0.2, UV Light Bricklet 2.0 2.0.1, Motion Detector Bricklet 2.0 2.0.2, IO-16 Bricklet 2.0 2.0.2, Remote Switch Bricklet 2.0 2.0.3, Dual Button Bricklet 2.0 2.0.1, Accelerometer Bricklet 2.0 2.0.1, IO-4 Bricklet 2.0 2.0.4, Motorized Linear Poti Bricklet 2.0.4, ePaper 128x296 Bricklet 2.0.1, Industrial Analog Out Bricklet 2.0 2.0.1, Voltage/Current Bricklet 2.0 2.0.3, Analog Out Bricklet 3.0 2.0.1, Distance IR Bricklet 2.0 2.0.1, Analog In Bricklet 3.0 2.0.3, One Wire Bricklet 2.0.1, GPS Bricklet 2.0 2.0.5, Industrial Quad Relay Bricklet 2.0 2.0.3, RS232 Bricklet 2.0 2.0.2, Sound Pressure Level Bricklet 2.0.3, Industrial Digital In 4 Bricklet 2.0 2.0.2, Isolator Bricklet 2.0.1, RGB LED Bricklet 2.0 2.0.1, Thermocouple Bricklet 2.0 2.0.2, Temperature Bricklet 2.0 2.0.1, Solid State Relay Bricklet 2.0 2.0.3, Hall Effect Bricklet 2.0 2.0.1, Humidity Bricklet 2.0 2.0.6, Industrial Dual Relay Bricklet 2.0.3, RGB LED Matrix Bricklet 2.0.2, Industrial Dual Analog In Bricklet 2.0 2.0.1, Industrial Counter Bricklet 2.0.2, Industrial Digital Out 4 Bricklet 2.0 2.0.2, Ambient Light Bricklet 3.0 2.0.1, Piezo Speaker Bricklet 2.0 2.0.1, Load Cell Bricklet 2.0 2.0.2, Laser Range Finder Bricklet 2.0 2.0.1, PTC Bricklet 2.0 2.0.2
  • Fix SPITFP IRQ race condition with other higher priority IRQs
Download: CAN Bricklet 2.0, Temperature IR Bricklet 2.0, NFC Bricklet, Linear Poti Bricklet 2.0, Segment Display 4x7 Bricklet 2.0, Joystick Bricklet 2.0, LCD 128x64 Bricklet, Particulate Matter Bricklet, DMX Bricklet, Outdoor Weather Bricklet, Thermal Imaging Bricklet, LED Strip Bricklet 2.0, OLED 128x64 Bricklet 2.0, RS485 Bricklet, Industrial Dual 0-20mA Bricklet 2.0, Rotary Encoder Bricklet 2.0, CO2 Bricklet 2.0, RGB LED Button Bricklet, UV Light Bricklet 2.0, Motion Detector Bricklet 2.0, IO-16 Bricklet 2.0, Remote Switch Bricklet 2.0, Dual Button Bricklet 2.0, Accelerometer Bricklet 2.0, IO-4 Bricklet 2.0, Motorized Linear Poti Bricklet, ePaper 128x296 Bricklet, Industrial Analog Out Bricklet 2.0, Voltage/Current Bricklet 2.0, Analog Out Bricklet 3.0, Distance IR Bricklet 2.0, Analog In Bricklet 3.0, One Wire Bricklet, GPS Bricklet 2.0, Industrial Quad Relay Bricklet 2.0, RS232 Bricklet 2.0, Sound Pressure Level Bricklet, Industrial Digital In 4 Bricklet 2.0, Isolator Bricklet, RGB LED Bricklet 2.0, Thermocouple Bricklet 2.0, Temperature Bricklet 2.0, Solid State Relay Bricklet 2.0, Hall Effect Bricklet 2.0, Humidity Bricklet 2.0, Industrial Dual Relay Bricklet, RGB LED Matrix Bricklet, Industrial Dual Analog In Bricklet 2.0, Industrial Counter Bricklet, Industrial Digital Out 4 Bricklet 2.0, Ambient Light Bricklet 3.0, Piezo Speaker Bricklet 2.0, Load Cell Bricklet 2.0, Laser Range Finder Bricklet 2.0, PTC Bricklet 2.0
