photron Geschrieben June 8, 2018 at 10:08 Autor Geschrieben June 8, 2018 at 10:08 Bindings: C/C++ 2.1.20, C# 2.1.18, Delphi/Lazarus 2.1.19, Java 2.1.18, JavaScript 2.0.18, LabVIEW 2.1.17, Mathematica 2.1.17, MATLAB/Octave 2.0.18, Perl 2.1.17, PHP 2.1.17, Python 2.1.17, Ruby 2.1.17, Shell 2.1.17, Visual Basic .NET 2.1.17 Add support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, RS232 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current 2.0 Bricklet [all]Add get/set_maximum_timeout functions to NFC Bricklet API [all]Add is_sensor_connected function and SENSOR_CONNECTED callback to PTC Bricklet API [all]Break Humiditiy 2.0, Rotary Encoder 2.0 and Temperature IR 2.0 Bricklet API to fix types for callback threshold min/max configuration [all]Fix string (un)packing for non-ASCII chars [Ruby]Add general streaming support [JavaScript] Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, Visual Basic .NET
photron Geschrieben June 8, 2018 at 14:49 Autor Geschrieben June 8, 2018 at 14:49 Brick Viewer 2.3.15 Add support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, RS232 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current 2.0 BrickletAdd Data Logger support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current 2.0 BrickletAdd Data Logger support for logging all stations and sensors with the Outdoor Weather Bricklet Downloads: Windows, Linux, Mac OS X
photron Geschrieben June 8, 2018 at 14:54 Autor Geschrieben June 8, 2018 at 14:54 Brick Logger 2.0.7 Add support for CAN 2.0, Industrial Counter, Industrial Digital In 4 2.0, Industrial Dual Relay, Industrial Quad Relay 2.0, IO-4 2.0, LED Strip 2.0, Load Cell 2.0, Particulate Matter, PTC 2.0, Real-Time Clock 2.0, Sound Pressure Level, Thermocouple 2.0 and Voltage/Current Bricklet 2.0 Downloads: Windows, Linux, Mac OS X, RED Brick
photron Geschrieben June 13, 2018 at 09:54 Autor Geschrieben June 13, 2018 at 09:54 RED Brick Image 1.12 Fix booting with an RS485 Extension presentUpdate Brick Viewer to version 2.3.15pdate all API bindings: C/C++ 2.1.20, C# 2.1.18, Delphi/Lazarus 2.1.19, Java 2.1.18, JavaScript 2.0.18, Octave 2.0.18, Perl 2.1.17, PHP 2.1.17, Python 2.1.17, Ruby 2.1.17, Shell 2.1.17, Visual Basic .NET 2.1.17 Download: RED Brick Image
photron Geschrieben July 16, 2018 at 15:12 Autor Geschrieben July 16, 2018 at 15:12 Brick Daemon 2.3.2 Fix notification event name handling on Windows 10 IoT CoreRead USB string descriptors instead of faking them on Windows 10 IoT CoreAdd backward compatibility to RED Brick Image 1.9Update bundled libusb to 1.0.22 on Windows and macOS, this fixes enumeration problems with ASMedia USB hubs, composite devices and bogus USB device address reports on WindowsAdd MSVC project on WindowsUse systemd instead of init.d on Linux, if availableAdd initial Android support, no precompiled app available yet, brickd for Android has to be compiled from source Downloads: Windows, Linux (amd64, i386, armhf), macOS
borg Geschrieben July 20, 2018 at 13:56 Geschrieben July 20, 2018 at 13:56 Firmware: IMU Brick 2.0 2.0.13 Add support for fusion mode without fast magnetometer calibration Download: IMU Brick 2.0
borg Geschrieben July 31, 2018 at 14:40 Geschrieben July 31, 2018 at 14:40 Firmwares: DC Brick 2.3.8, IMU Brick 2.3.8, Master Brick 2.4.9, Servo Brick 2.3.7, Silent Stepper Brick 2.0.7, Stepper Brick 2.3.9 Add support for Isolator BrickletImprove Co-MCU Bricklet error handling Download: DC Brick, IMU Brick, Master Brick, Servo Brick, Silent Stepper Brick, Stepper Brick
photron Geschrieben August 8, 2018 at 08:30 Autor Geschrieben August 8, 2018 at 08:30 Firmware: Real-Time Clock Bricklet 2.0 2.0.1 Remove unnecessary I2C communication to avoid date-time jumps Download: Real-Time Clock 2.0
photron Geschrieben August 16, 2018 at 12:49 Autor Geschrieben August 16, 2018 at 12:49 Firmware: Real-Time Clock Bricklet 2.0 2.0.2 Make date-time/timestamp getters synchronous again to avoid potential timeouts Download: Real-Time Clock 2.0
photron Geschrieben September 28, 2018 at 13:09 Autor Geschrieben September 28, 2018 at 13:09 Bindings: C/C++ 2.1.21, C# 2.1.19, Delphi/Lazarus 2.1.20, Java 2.1.19, JavaScript 2.1.19, LabVIEW 2.1.18, Mathematica 2.1.18, MATLAB/Octave 2.0.19, Perl 2.1.18, PHP 2.1.18, Python 2.1.18, Ruby 2.1.18, Shell 2.1.18, Visual Basic .NET 2.1.18 Add support for Air Quality, Analog Out 3.0, Barometer 2.0, Distance IR 2.0, Dual Button 2.0, Industrial Analog Out 2.0, Industrial Digital Out 4 2.0, Industrial Dual 0-20mA 2.0, Industrial Dual Analog In 2.0, IO-16 2.0, Isolator, LCD 128x64, OLED 128x64 2.0, One Wire, Temperature 2.0 and UV Light 2.0 Bricklet [All]Fix compile errors in Delphi XE [Delphi/Lazarus]Convert all array parameters from static to open to accept dynamic arrays too [Delphi/Lazarus]Fix authentication server nonce packing [Perl]Fix single byte bool array unpacking Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, Visual Basic .NET
borg Geschrieben October 4, 2018 at 09:39 Geschrieben October 4, 2018 at 09:39 Firmwares: Thermocouple Bricklet 2.0 2.0.1, RGB LED Button Bricklet 2.0.1, Industrial Digital In 4 Bricklet 2.0 2.0.1, NFC Bricklet 2.0.2, PTC Bricklet 2.0 2.0.1, Remote Switch Bricklet 2.0 2.0.2, LED Strip Bricklet 2.0 2.0.1, Temperature IR Bricklet 2.0 2.0.2, Solid State Relay Bricklet 2.0 2.0.1, Humidity Bricklet 2.0 2.0.2, Outdoor Weather Bricklet 2.0.1, IO-4 Bricklet 2.0 2.0.1, RS485 Bricklet 2.0.2, Particulate Matter Bricklet 2.0.1, Industrial Quad Relay Bricklet 2.0 2.0.1, GPS Bricklet 2.0 2.0.4, Real-Time Clock Bricklet 2.0 2.0.3, Motion Detector Bricklet 2.0 2.0.1, Analog In Bricklet 3.0 2.0.2, RGB LED Matrix Bricklet 2.0.1, CAN Bricklet 2.0 2.0.1, Sound Pressure Level Bricklet 2.0.2, Industrial Dual Relay Bricklet 2.0.1, Thermal Imaging Bricklet 2.0.2, Voltage/Current Bricklet 2.0 2.0.1, DMX Bricklet 2.0.1, RS232 Bricklet 2.0 2.0.1, Motorized Linear Poti Bricklet 2.0.3, Load Cell Bricklet 2.0 2.0.1, Industrial Counter Bricklet 2.0.1 Fix race condition with potential buffer overflow (through bricklib2) Download: Thermocouple Bricklet 2.0, RGB LED Button Bricklet, Industrial Digital In 4 Bricklet 2.0, NFC Bricklet, PTC Bricklet 2.0, Remote Switch Bricklet 2.0, LED Strip Bricklet 2.0, Temperature IR Bricklet 2.0, Solid State Relay Bricklet 2.0, Humidity Bricklet 2.0, Outdoor Weather Bricklet, IO-4 Bricklet 2.0, RS485 Bricklet, Particulate Matter Bricklet, Industrial Quad Relay Bricklet 2.0, GPS Bricklet 2.0, Real-Time Clock Bricklet 2.0, Motion Detector Bricklet 2.0, Analog In Bricklet 3.0, RGB LED Matrix Bricklet, CAN Bricklet 2.0, Sound Pressure Level Bricklet, Industrial Dual Relay Bricklet, Thermal Imaging Bricklet, Voltage/Current Bricklet 2.0, DMX Bricklet, RS232 Bricklet 2.0, Motorized Linear Poti Bricklet, Load Cell Bricklet 2.0, Industrial Counter Bricklet
photron Geschrieben October 5, 2018 at 13:30 Autor Geschrieben October 5, 2018 at 13:30 Bindings: C/C++ 2.1.22, C# 2.1.20, Delphi/Lazarus 2.1.21, Java 2.1.20, JavaScript 2.1.20, LabVIEW 2.1.19, Mathematica 2.1.19, MATLAB/Octave 2.0.20, Perl 2.1.19, PHP 2.1.19, Python 2.1.19, Ruby 2.1.19, Shell 2.1.19, Visual Basic .NET 2.1.19 Break API to fix moving-average-length type in Distance IR Bricklet 2.0 API [All] Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, Visual Basic .NET
photron Geschrieben October 5, 2018 at 14:41 Autor Geschrieben October 5, 2018 at 14:41 Brick Viewer 2.3.16 Add support for Air Quality, Analog Out 3.0, Barometer 2.0, Distance IR 2.0, Dual Button 2.0, Industrial Analog Out 2.0, Industrial Digital Out 4 2.0, Industrial Dual 0-20mA 2.0, Industrial Dual Analog In 2.0, IO-16 2.0, Isolator, LCD 128x64, OLED 128x64 2.0, One Wire, Temperature 2.0 and UV Light 2.0 BrickletAdd Data Logger support for Air Quality, Analog Out 3.0, Barometer 2.0, Distance IR 2.0, Dual Button 2.0, Industrial Dual 0-20mA 2.0, Industrial Dual Analog In 2.0, IO-16 2.0, Temperature 2.0 and UV Light 2.0 BrickletAdd gain control to Load Cell Bricklet 2.0 pluginShow correct unit in UV Light Bricklet pluginMake Real-Time Clock Bricklet (2.0) calibration process more robustInstall start menu link for all users on Windows Downloads: Windows, Linux, macOS
photron Geschrieben October 5, 2018 at 14:49 Autor Geschrieben October 5, 2018 at 14:49 Brick Logger 2.0.8 Add support for Air Quality, Analog Out 3.0, Barometer 2.0, Distance IR 2.0, Dual Button 2.0, Industrial Dual 0-20mA 2.0, Industrial Dual Analog In 2.0, IO-16 2.0, Temperature 2.0 and UV Light 2.0 Bricklet Downloads: Windows, Linux, macOS, RED Brick
borg Geschrieben October 15, 2018 at 16:05 Geschrieben October 15, 2018 at 16:05 Firmware: Humidity Bricklet 2.0 2.0.3 Add support for SetSamplesPerSecond function Download: Humidity Bricklet 2.0
borg Geschrieben October 16, 2018 at 15:08 Geschrieben October 16, 2018 at 15:08 16 new Bricklets Blog entry
photron Geschrieben November 6, 2018 at 13:39 Autor Geschrieben November 6, 2018 at 13:39 Firmware: RS485 Bricklet 2.0.3 Fix response length for modbus_master_write_single_register and modbus_master_write_single_coil functions Download: RS485 Bricklet
photron Geschrieben November 7, 2018 at 11:21 Autor Geschrieben November 7, 2018 at 11:21 Firmware: Voltage/Current Bricklet 2.0 2.0.2 Fix two's complement handling for negative current measurement Download: Voltage/Current Bricklet 2.0 2.0.2
photron Geschrieben November 19, 2018 at 11:03 Autor Geschrieben November 19, 2018 at 11:03 RED Brick Image 1.13 Disable drm_kms_helper polling to solve system stalls every 10 secondsAdd Lua 5.3 interpreterEnable loopback device supportUpdate Brick Daemon to version 2.3.2Update Brick Viewer to version 2.3.16Update all API bindings: C/C++ 2.1.22, C# 2.1.20, Delphi/Lazarus 2.1.21, Java 2.1.20, JavaScript 2.0.20, Octave 2.0.20, Perl 2.1.19, PHP 2.1.19, Python 2.1.19, Ruby 2.1.19, Shell 2.1.19 und Visual Basic .NET 2.1.19 Download: RED Brick Image
photron Geschrieben November 19, 2018 at 11:03 Autor Geschrieben November 19, 2018 at 11:03 Firmware: LCD 128x64 Bricklet 2.0.1 Make the clear-display function obey the automatic-draw config Download: LCD 128x64 Bricklet 2.0.1
photron Geschrieben November 28, 2018 at 14:22 Autor Geschrieben November 28, 2018 at 14:22 Bindings: C/C++ 2.1.23, C# 2.1.21, Delphi/Lazarus 2.1.22, Java 2.1.21, JavaScript 2.1.21, LabVIEW 2.1.20, Mathematica 2.1.20, MATLAB/Octave 2.0.21, Perl 2.1.20, PHP 2.1.20, Python 2.1.20, Ruby 2.1.20, Shell 2.1.20, Visual Basic .NET 2.1.20 Add get/set_samples_per_second functions to Humidity Bricklet 2.0 APIAdd button, slider, graph and tab functions to LCD 128x64 Bricklet API Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, Visual Basic .NET
borg Geschrieben November 28, 2018 at 14:35 Geschrieben November 28, 2018 at 14:35 Firmware: LCD 128x64 Bricklet 2.0.2 Fix backlight PWM (value of zero is now completely off)Use CIE 1931 lookup-table for backlight intensity correctionFix Status/Touch LED mixupAdd Set/GetTouchLEDConfig APIAdd API for simple GUI elements with touch support Download: LCD 128x64 Bricklet 2.0.2
borg Geschrieben November 28, 2018 at 14:42 Geschrieben November 28, 2018 at 14:42 Graphical User Interface for LCD 128x64 Blog entry
borg Geschrieben November 29, 2018 at 09:36 Geschrieben November 29, 2018 at 09:36 Some bugs were already found and fixed in the new LCD API: Firmware: LCD 128x64 Bricklet 2.0.3 + 2.0.4 + 2.0.5 Fix off-by-one in GUI graph height calcultionFix bug in GUI remove functionsFix wrong initialization of touch LEDMake sure display is updated on GUI remove-event Download: LCD 128x64 Bricklet 2.0.5
rtrbt Geschrieben December 21, 2018 at 14:44 Geschrieben December 21, 2018 at 14:44 Bindings: Rust 2.0.7 First stable release Download: http://download.tinkerforge.com/bindings/rust/tinkerforge_rust_bindings_2_0_7.zip
