Brick Daemon 2.2.2
  • Use uname to get RED Brick kernel release for loading Ethernet Extension kernel driver (hotfix-1: already released as part of RED Brick Image 1.6)
  • Improve RED Brick SPI stack protocol error recovery (hotfix-2: already released as part of RED Brick Image 1.7)
  • Add start menu link for logviewer.exe on Windows
  • Adapt to file system protection changes in Mac OS X 10.11
  • Update libusb WDF co-installer for Windows Vista and 7
Downloads: Windows, Linux (amd64, i386, armhf), Mac OS X
Brick Viewer 2.3.0
  • Add data logger for Bricks and Bricklets
  • Show WIFI and GSM signal quality on RED Brick Network and Mobile Internet tab
  • Make SIM PIN optional for RED Brick Mobile Internet service
  • Add "Test Email" button to RED Brick Server Monitoring tab
  • Add support for more openHAB config file types (.persist, .script and .transform) to RED Brick plugin
  • Reduce Mobile Internet connection checks to reduce RED Brick CPU load
  • Add configurable line ending for RS232 Bricklet plugin
  • Handle split multi-byte line ending correctly in RS232 Bricklet plugin
  • Add error counters to RS232 Bricklet plugin
  • Add support for unlimited range and out-of-range and overflow states to Ambient Light Bricklet 2.0 plugin
  • Show Master Extensions in devices tree
  • Sort device tree by position by default
  • Fix download of non-ASCII log files from RED Brick
Bindings: C/C++ 2.1.8, C# 2.1.7, Delphi/Lazarus 2.1.8, Java 2.1.6, JavaScript 2.0.6, LabVIEW 2.1.6, Mathematica 2.1.6, MATLAB/Octave 2.0.6, Perl 2.1.6, PHP 2.1.6, Python 2.1.6, Ruby 2.1.6, Shell 2.1.6, VB.NET 2.1.6
  • Add missing constant for 19200 baud to RS232 Bricklet API [all]
  • Add error callback to RS232 Bricklet API [all]
  • Add set_break_condition function to RS232 Bricklet API [all]
  • Add unlimited illuminance range constant to Ambient Light Bricklet 2.0 API [all]
  • Break API to fix threshold min/max type mismatch in Ambient Light, Analog In (2.0), Distance IR/US, Humidity, Linear Poti and Voltage Bricklet API [all]
  • Break API to fix bool return type mismatch in Servo Brick (is_position_reached_callback_enabled and is_velocity_reached_callback_enabled function), Accelerometer Bricklet (is_led_on function) and Load Cell Bricklet (is_led_on function) API [all]
  • Avoid race condition in callback thread destruction [C/C++]
  • Avoid warnings about experimental reference access patterns [Perl]
  • Don't decode non-ASCII strings and chars in Python 3 [Python]
Download: C/C++, C#, Delphi/Lazarus, Java, JavaScript, LabVIEW, Mathematica, MATLAB/Octave, Perl, PHP, Python, Ruby, Shell, VB.NET
This release brakes API in two places. Programs that use the affected functions have to be adapted. The change is about the parameter and return types of some functions. Because of that only strictly typed languages are affected: C/C++, C#, Delphi/Lazarus, Java and VB.NET. In all cases the changes will reveal themself as compile error, so no change can be missed.
