muekno Geschrieben February 5, 2020 at 12:43 Share Geschrieben February 5, 2020 at 12:43 Ich habe ein PI mit dem aktuelle RASBIAN BUSTER TINY aktuelle Patches, d.h. ohne Tastatur und Bildschirm. verbinde über SSH. Habe nach dieser https://www.tinkerforge.com/de/doc/Embedded/Raspberry_Pi.html anleitung alles fehlerfrei installiert, bekomme aber beim start von brickd -- Support: https://www.debian.org/support -- -- The unit brickd.service has entered the 'failed' state with result 'exit-code'. Feb 05 13:25:18 CAN systemd[1]: Failed to start Brick Daemon. -- Subject: A start job for unit brickd.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit brickd.service has finished with a failure. -- -- The job identifier is 682 and the job result is failed. Feb 05 13:26:57 CAN systemd[1]: Starting Brick Daemon... -- Subject: A start job for unit brickd.service has begun execution -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit brickd.service has begun execution. -- -- The job identifier is 739. Feb 05 13:26:57 CAN brickd[3213]: Error(s) occurred while reading config file '/etc/brickd.conf' Feb 05 13:26:57 CAN systemd[1]: brickd.service: Control process exited, code=exited, status=1/FAILURE -- Subject: Unit process exited -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- An ExecStart= process belonging to unit brickd.service has exited. -- -- The process' exit code is 'exited' and its exit status is 1. Feb 05 13:26:57 CAN systemd[1]: brickd.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit brickd.service has entered the 'failed' state with result 'exit-code'. Feb 05 13:26:57 CAN systemd[1]: Failed to start Brick Daemon. -- Subject: A start job for unit brickd.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit brickd.service has finished with a failure. benötige Hilfe, Danke Rainer Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben February 5, 2020 at 13:09 Share Geschrieben February 5, 2020 at 13:09 Irgendetwas stimmt mit /etc/brickd.conf nicht und Brick Daemon kann sie nicht lesen. Führe bitte diesen Befehl auf dem Raspberry Pi aus: sudo brickd --check-config Der sollte ausgeben was mit /etc/brickd.conf nicht stimmt. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
muekno Geschrieben February 5, 2020 at 14:02 Autor Share Geschrieben February 5, 2020 at 14:02 root@CAN:~# sudo brickd --check-config Unexpected error ERANGE (34) occurred Error(s) occurred while reading config file '/etc/brickd.conf' Das heisst für mich Zeile 34 hat einen Fehler, Ausschnitt der brickd.conf 28 # The default values are 0.0.0.0, 4223, 0 (disabled), 4240 and off. 29 listen.address = 0.0.0.0 30 listen.plain_port = 4223 31 listen.websocket_port = 4280 # 32 listen.mesh_gateway_port = 4240 33 listen.dual_stack = off 34 35 # Network Authentication 36 # Zeilenummern habe ich händisch eingefügt, was soll an einer Leerzeile die original vorhanden ist falsch sein. Geändert habe ich an der Datei nur den Port für den websocket_port Gruß Rainer Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
muekno Geschrieben February 5, 2020 at 14:42 Autor Share Geschrieben February 5, 2020 at 14:42 Habe jetzt testhalber Leere Zeile 34 gelöscht und der Check geht durch, unverständlich Gruß RAiner Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben February 5, 2020 at 14:55 Share Geschrieben February 5, 2020 at 14:55 Unexpected error ERANGE (34) occurred Die 34 da bedeutet nicht Zeile 34, sondern das der Fehler ERANGE die Nummer 34 hat. Kommt der Fehler wieder, wenn du die leere Zeile wieder einfügst? Häng doch mal bitte die ganze /etc/brickd.conf Datei an. Das # am Ende der websocket_port Zeile ist da nicht erlaubt. Kommentare können nicht am Ende einer Zeile stehen, sondern nur am Anfang. Das ist aber hier nicht das Problem. ERANGE besagt hier etwas anderes kaputt ist. Leider gibt die Meldung nicht her was genau das Problem ist. Ich werde das gleich mal verbessern. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
