tried to setup an Air Quality Bricklet for MQTT Callback with a Raspberry Pi 4 running mosquito and the Tinkerforge MQTT Binding 2.0.6.
The Brick Viewer shows all data; An MQTT request provides also the data (see below …/get_all_values request with response), but with MQTT callback no response.
Question: what is wrong in below configuration?
pi@4dev:~ $ mosquitto_pub -t tinkerforge/request/air_quality_bricklet/Jvj/set_all_values_callback_configuration -m '{"period": 100, "value_has_to_change":false}'
pi@4dev:~ $ mosquitto_pub -t tinkerforge/register/air_quality_bricklet/Jvj/all_values -m '{"register": true}'
OUTPUT
pi@4dev:~ $ mosquitto_sub -v -t tinkerforge/#
tinkerforge/request/air_quality_bricklet/Jvj/set_all_values_callback_configuration {"period":10,"value_has_to_change":false}
tinkerforge/register/air_quality_bricklet/Jvj/all_values {"register":true}
tinkerforge/request/air_quality_bricklet/Jvj/get_all_values {}
tinkerforge/response/air_quality_bricklet/Jvj/get_all_values {"iaq_index": 26, "iaq_index_accuracy": "low", "temperature": 2100, "humidity": 5403, "air_pressure": 102912}
The configuration seems to be correct. You could try the following:
  • Run the bindings with --debug
  • Read back the callback configuration with
     mosquitto_pub -t tinkerforge/request/air_quality_bricklet/Jvj/get_all_values_callback_configuration -m ''
    after you've set it.
Also the period is in milliseconds, so 10 should work, but will flood you with data that will be very often identical.
Please find the output of running the bindings with parameter --debug.
Changed the period to 5000.
2020-01-24 10:10:29,786 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m582), 'b'tinnse/air_quality_bricklet/Jvj/get_all_values_callback_configuration'', ... (46 bytes)
2020-01-24 10:10:48,678 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m586), 'b'tinkerforge/callback/air_quality_bricklet/Jvj/all_values'', ... (109 bytes)
2020-01-24 10:10:53,637 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m587), 'b'tinkerforge/callback/air_quality_bricklet/Jvj/all_values'', ... (109 bytes)
2020-01-24 10:10:58,600 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m588), 'b'tinkerforge/callback/air_quality_bricklet/Jvj/all_values'', ... (109 bytes)
2020-01-24 10:11:03,561 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m589), 'b'tinkerforge/callback/air_quality_bricklet/Jvj/all_values'', ... (109 bytes)
2020-01-24 10:11:08,513 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m590), 'b'tinkerforge/callback/air_quality_bricklet/Jvj/all_values'', ... (109 bytes)
2020-01-24 10:11:13,478 <DEBUG> paho.mqtt.client: Sending PUBLISH (d0, q0, r0, m591), 'b'tinkerforge/callback/air_quality_bricklet/Jvj/all_values'', ... (109 bytes)
