Cathodion Geschrieben June 19, 2012 at 13:56 Geschrieben June 19, 2012 at 13:56 Hey all, I just ordered a USB extender that uses UTP cables to connect USB devices up to 50m away. I'm going to try to connect a brick using this extender to my PC. This is the product I ordered: http://www.informatique.nl/925047/konig-usb-verlenger-via-utp-50m.html If this works as expected I will use these to distribute bricks throughout my house and garage while the PC (or Raspberry Pi) stays in a central place. I'll let you know about my findings. Kind regards, Geert Schuring. Zitieren
Loetkolben Geschrieben June 19, 2012 at 16:54 Geschrieben June 19, 2012 at 16:54 Thanks for information, but keep in mind that this is a USB 1.1 Extender! If you use USB 2.0 Devices on both sides, errors may occur. Maybe you can switch down your PC USB Port to USB 1.1 or better try this: PC_with_USB20 --- old_USB1.1_aktive_Hub --- Extender ~~CAT~~ Extender --- Masterbrick. This should give USB1.1 signals onto Extenderconnection! If you use an 4 Port USB 1.1 active Hub, you can connect 4 Extender to it. Der Loetkolben Zitieren
Cathodion Geschrieben June 19, 2012 at 20:08 Autor Geschrieben June 19, 2012 at 20:08 Since USB has always been backwards compatible, I'm assuming the extender will simply cause my PC USB port to switch to USB 1.1 automatically the same way a USB 1.1 hub would if I connect it to the PC. I just got confirmation that the order has been shipped today, so I guess we'll find out tomorrow after I get back from work. Zitieren
Cathodion Geschrieben June 20, 2012 at 18:49 Autor Geschrieben June 20, 2012 at 18:49 I got the extender today, and it works totally perfect!!! Just plug and play... and enjoy your 50 meter USB connection. Nothing more to say about it really. Its so simple. Zitieren
Loetkolben Geschrieben June 20, 2012 at 20:52 Geschrieben June 20, 2012 at 20:52 Thanks for feedback and have much fun with this piece of hardware. :-)) If you more news regarding this toppic please let us know. :-) Der Loetkolben Zitieren
