cl- Geschrieben October 9, 2019 at 10:02 Geschrieben October 9, 2019 at 10:02 Hi! Would it be possible to make the path to the docker executable editable for your docker based build environment? At the moment, the command in your makefile configuration files (inside the bricklib2/cmake folder) include the static path, that is /usr/bin/docker. On a mac, for instance, docker doesn't install into /usr/bin though. It would be possible for me to change all these occurrences, that's not the question. However, I don't want to change that many files, given that I don't want conflicts in the cloned git repository. Cheers, Claudio Zitieren
borg Geschrieben October 10, 2019 at 07:39 Geschrieben October 10, 2019 at 07:39 I just replaced "/usr/bin/docker" with "docker" for now (we were using "docker" at other places in the Makefile anyway). If the docker binary is not somewhere in $PATH you can always call make with PATH=$PATH:/your/path to make it work. Zitieren
cl- Geschrieben October 10, 2019 at 12:42 Autor Geschrieben October 10, 2019 at 12:42 Thanks! I've seen the changes in bricklib2. There are also two files in /bricklib/toolchains with the absolute path to docker. Cheers! Zitieren
borg Geschrieben October 10, 2019 at 14:17 Geschrieben October 10, 2019 at 14:17 Indeed, it is fixed now. Zitieren
