tommichiels Geschrieben July 15, 2019 at 09:39 Share Geschrieben July 15, 2019 at 09:39 Hi, After months of good service, my red brick is no longer visible in the brick viewer. I tried to re-plug it, and eject and re-insert the SD card, but that did not help. Any idea's? Did my red brick die? Thanks, Tom Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 15, 2019 at 10:18 Share Geschrieben July 15, 2019 at 10:18 Please check if the three LEDs on the RED Brick light up in the documented sequence: https://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#leds If they don't, what's the sequence you're seeing when you power up the RED Brick? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
tommichiels Geschrieben July 15, 2019 at 21:46 Autor Share Geschrieben July 15, 2019 at 21:46 Thanks for the quick reply! The sequence is stopped with a solid green light. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 16, 2019 at 09:10 Share Geschrieben July 16, 2019 at 09:10 Okay, that means that the RED Brick did not fully boot up. This can be an issue with the SD card itself or the file system on the SD card. If you don't have any important data stored on the SD card then you could try flashing a fresh RED Brick image to the SD card: https://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#copy-image-to-sd-card Alternatively, if you have another SD card similar to the RED Brick one then you could try flashing a fresh RED Brick image to that SD card instead. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
